The lid of the tape deck on my BC 9300 has got a few scratches. Not very much, but it would be nice if there was a way to remove them. What material are the lids made of? Do you think it is possible to make them go away by polishing? You can feel the scratches when you run a finger nail across them. Or should I try to find a donor lid?
/riis
