1st March February 2012
Latest post 02-25-2010 3:40 PM by Peter. 11 replies.
02-21-2010 7:19 AM
Orava
- Joined on 10-25-2009
- Finland
- Posts 28
Hello
Does anyone know why MMC5's are often more wanted than, for example MMC3's?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=130367447659&ssPageName=STRK:MEWAX:IT
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=130367448741&ssPageName=STRK:MEWAX:IT
Identical ads, and MMC5 getting more. I have notice this on other auctions too. On other hand MMC2 could rise up to 300.
Have I missed something?? Or is ther e something wrong with MMC3 or 4 versus MMC5?
Medogsfat
- Joined on 02-21-2007
- *Moderator* Leeds, Yorkshire
- Posts 4,045
The only reason I can think of is that people must think that the higher the number, the more highly specified the cartridge is.
A fair assunption to make if you don't know.
Chris.
cjocc
- Joined on 09-07-2007
- Sweden
- Posts 39
Hello,
Why dont you have a look at the following page and their links to MMC1-5. Links under Related Products at bottom of page. It seems the MMC1 and 2 is way better than 3-5, but also were replacement for other ranges of B&O products.
Another alternative is to give the http://www.sound-smith.com/ a call. It seems they now anything worth knowing about B&O cartridges!! From them you can also buy "original" cartridges instead of "semi-new" on e-bay! Have a look at http://www.sound-smith.com/cartridges/boall.html
Cheers
cjocc
BC 2, MX7000, BeoPort, BLab 35000,BLab 3,BLab 8000,BeoC 6000, Beo4
9 LEE
- Joined on 02-14-2007
- Moderator - UK
- Posts 5,223
You could always hammer a nail into a matchstick and drag it across your vinyl if you fancied an alternative to an MMC5...
I'm with Chris on this one - people must think the higher then number, the better the MMC cartridge. I can say the MMC1 gives near CD-Quality reproduction (to my ears at least) on good quality vinyl, the MMC2 is excellent, the MMC3 is good, the MMC4 is perfectly acceptable and the MMC5 is a shard of glass welded to a hat pin.
That said, i profess to knowing nothing and wait to be corrected...
Lee
Orava
- Finland
- Posts 28
Yes, even I can hear difference between MMC5 and MMC4, have listen them both on beosystem 4500, and in beogram 5005 connected to beocenter 3300.
Unfortunally higher cartridges are so expensive that I can't buy them just for testing...
and MMC4000 is pretty fine too in my BC3300.
Peter
- Joined on 02-12-2007
- Posts 9,572
Actually I am going to be controversial here! I reckon all the MMC1-5 cartridges are not bad, even the MMC5. Having seen the tip of an MMC4 under an electron microscope, it is only just elliptical and the MMC5 is not much different. I have compared cartridges fairly widely and there is a definite B&O in house sound and all of these cartridges have it. For stereo reproduction, the major difference is that the lower grade cartridges exhibit a degree of sibilance. They also do not track quite so well and hence have a higher tracking weight.
I cannot distinguish between a MMC1 or 2 - both are excellent and indeed there is some debate as to whether the MMC1 is a different design or is in fact a selected version of the MMC2. This is actually not an uncommon scenario with the Beogram 8000 and 6006 also being to all intents identical.
ouverture
- Joined on 04-20-2007
- London
- Posts 282
I agree more or less with Peter, the MMC1 and 2 are excellent, I have only heard the MMC1 on one B&O table, but it was not detectably different enough from the MMC2 when we kept swapping them over.
I have never heard an MMC3, so I cannot comment, but I have heard lots of MMC4 and 5, and to my mind the 4 is easily more capable than the 5, and Peter is spot on about the sibiliance factor on the 4 and 5 cartridges, more noticeably so I felt on the MMC5
if you can find an MMC2 in any condition, it is worth having IMHO
Page 1 of 1 (12 items)
