Latest post 02-18-2010 8:32 PM by SWISS_2. 2 replies.
Page 1 of 1 (3 items)
  • 02-18-2010 12:31 PM
    Please Suggest Ideas for a Home Theater Setup
    Hi All:
    hopefull would like to set up a home theater system and was thinking baout using following
    1. Beocenter 2 or Beosound 4
    2. Beolab 3 - R and L Speakers
    3. Beaolab 2 - woofer
    4 - suggestions needed for the center/rear left and right
    Please share any thoughts what will be a good setup considering overall cost and increase efficeincy in use of equipment
    Beovox RL 60.2, RL 6000, S45-2, CX 50, Cona, Beolink Passive, MCL2P, BM4500, Beosound 1, Beocenter 2500, Beolab 2500, Besound 4000, Beolab 4000, Beocom 6000, A8, Beosystem 1
  • 02-18-2010 6:13 PM In reply to
    Re: Please Suggest Ideas for a Home Theater Setup
    sodoi18:
    Hi All:
    What is the screen/ TV? Many who use Avant or Beovision 5 televisions would argue that you get a very adequate experience without necessarily using additional speakers. If thr room is not too large and you are not buying new, these televisions can give a full cinema experience on their own.
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
  • 02-18-2010 8:32 PM In reply to
    • SWISS_2
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Neuchatel, Suisse
    • Posts 552
    • Gold Member
    Nice concept for a Home Theatre system.
    In addition to the other good questions just posted above, I might also ask if you are considering the merits of a HT PC (computer ) with MCE capabilities included in your HT system ?  This provides the opportunity to work on the computer, display downloaded music and movies, N.MUSIC,  N.RADIO, etc. ( with a Beoport PC ) and also gives you a second  DVD and HD drive to use.
    We use a Beosound 3200 as a HT system master, with BL 4000 front speakers, and BL 4 rear speakers. The BL 4000 are sitting adjacent to the BS 4000 as B&O intended, but the BL 4 pair (after some sound trials ) were ultimately attached to the ceiling. The latter came as a suggestion from a B&O store owner, and given the improved sound, proved to be a very good idea. Note also these units are all hard-wired through the house, and connected using the B&O Master Link cable system.
