Latest post 02-22-2010 2:24 PM by Jackplug. 4 replies.
Page 1 of 1 (5 items)
  • 02-16-2010 3:43 PM
    Mark II DVD Controller codes for Panasonic DMR-EX77
    Does anyone have a copy of the codes for Panasonic DVD players / recorders?  I'm guessing that a general code for Panasonic will suffice but I don't know what it is, any ideas?   Also, do B&O dealers give away the function conversion tables or are they available on Beoworld?
    Many thanks.
    Jack
    BV10(40) BV8-32, BV3-32, MX7000, DVD1, HDR1, V8000
    Beomedia-1, BS9000, BC7002, BC2300, BS5500, BM6500, BGCD6500, BM1900-2
    BL5, BL8000, BL6000, BL Penta3, BL3500
    Beovox MC120.2, 3000 Panels, CX50s, C75s, AND LOTS WIRES, BOOkS, MAGS n BITS (ebay sales: beo-store-uk)
  • 02-21-2010 9:47 AM In reply to
    Re: Mark II DVD Controller codes for Panasonic DMR-EX77
    Unless you have access to the service tool (You should not) and know how to use it and avoid wrecking your TV. You can`t do this yourself.
  • 02-21-2010 9:53 AM In reply to
    If you are using the DVD-C you don't need the service tool - the DVD-C is a posh SCART lead with an IR sensor. The code for the DMR-E50 should work and is 06. The cards are on Beoworld but your dealer will have them too.
  • 02-22-2010 1:35 PM In reply to
    Thanks Peter, I'll give it another try tonight and see what happens.  Is the code '06' something that sets the DVD controller itself or is this something that the TV needs to be set to.  Setup seems to be via Beo4  'TUNE' process?  It's a Mark 2 DVD controller if that makes any difference as I don't know what is meant by the ref DVD-C  (unless that Beoworld speak for the same device) :-)
    Jack
  • 02-22-2010 2:24 PM In reply to
    Right, OK I got the DVD Controller to work now but only vey basic functions, i.e. PLAY, PAUSE and STOP plus a functions menu via the Beo4 coloured buttons.  So I need the conversion tables which Peter says are on Beoworld but I've not been able to find them?
    Any ideas as to where on here I can view them
    Many many thanks - as usual...
    Jack
