I'm a bit disappointed with that "triangle shifting" update, I expected B&O to do exactly the opposite of what they've done, that is: give us a full screen and all-time BeoPort interface rather than hiding it completely! What's the point in designing such a beautiful interface if it is always hidden? I have a PC that's entirely dedicated to BeoPort, I don't want to see anything else than its interface. With the new update, you can have full screen for each source after pressing the source+info , but every time you go to another source, the screen goes blank again..
Apart from that, the new feature I noticed is that you can now watch your photos AND listen to music at the same time, just start both sources and they will work..
No radical change on the rest:
- still gaps during NMUSIC playback
- it says WAV files are supported but I never managed to find them when scanning
- NRADIO still shows no metadata about track & artist names
- when a NRADIO program is finished, still no shifting to the next available station
- same when connection failed, there's no redirection to the next station, like what happens when your CD track is scratched
- still no way to add NRADIO stations manually
- still no way to select a higher bitrate than 96 kbps when setting up NRADIO
- still no control of PHOTO with Beo4
- still no possibility to use BeoPort as an audio master
OK, I'll stop here..I love this software!
Reunion Island is greeting you!
