Latest post 02-28-2010 4:38 AM by DrDimitris. 3 replies.
Page 1 of 1 (4 items)
  • 02-16-2010 6:49 AM
    • YannChris
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Larmor-Plage, France
    • Posts 276
    Beoport 64bits
    Hello!
    At last it happened:
    Version 5.04.00
    New features included:
    • BeoPort to run on Microsoft Windows 64 bit OS
    • Possibility disabling the BeoPlayer control bar and info bar to slide in from the left and right of the screen
    Error correction:
    • A number of minor error corrections have been made.
    System Requirements
    • Windows® 7 (32 and 64 bit)
    • Windows® Vista, Service Pack 1 or 2 (32 and 64 bit)
    • Windows® XP, Service Pack 3 (32 and 64 bit)
    • Internet connection
    • One free USB port
    • DirectX 8.0 or higher
    • Windows® Media Player 9.0 or higher
    Yann.
    Ne pas s'en faire et boire frais!
    Mon install en images: cliquez sur mon profil, au dessus de mon avatar - Puis "My files" tout en bas.
    Pictures of my setup: click on my nickname, above my avatar. Then "my files" at the bottom of the page.
  • 02-25-2010 8:41 AM In reply to
    Re: Beoport 64bits
    thanks Yann, where did you download it from -  may I ask ??
  • 02-25-2010 3:13 PM In reply to
    • dko7113
    • Top 500 Contributor
    • Joined on 09-04-2008
    • Copenhagen, Denmark
    • Posts 104
    • Gold Member
    Re: Beoport 64bits
    My Beo: BeoCom 6000, BeoCom 2500, BeoCom 1401, BeoLine, BeoVision LX6000, BeoVision LX2500, BeoVision MS6000, BeoVision MX4002, BeoVision MX1500, DVD1, BeoSound 3200, BeoSound 1, BeoLab 4000, BeoGram 4500, BeoPort, BeoPlayer, 3x Beo 4, 2x BeoLink 1000, V Terminal, Form 2, Light Control 2, BeoTime
  • 02-28-2010 4:38 AM In reply to
    Re: Beoport 64bits
    After installing the new software, i noticed that Beomedia1 which is on the same link with Beoport keeps restarting constantly. Has anyone noticed something like that and do you have an idea about the remedy on this?
    -Dimitris
