Latest post 02-15-2010 11:17 PM by Chrisreunion. 1 replies.
Page 1 of 1 (2 items)
  • 02-15-2010 7:32 PM
    Is the Lutron GBO 3103 Light Controller compatible with the Beolink 7000 and Beolink 1000?
    The Lutron manual says it is for the Beo4. I'm wondering if the other remotes send the same light codes.
  • 02-15-2010 11:17 PM In reply to
    Re: Is the Lutron GBO 3103 Light Controller compatible with the Beolink 7000 and Beolink 1000?
    If it works for Beo4, it will work with all other B&O remotes, including the keyring.
    Reunion Island is greeting you!
