Good news: it should be better than Beo5 (it is called Beo6, not Beo3)
Bad news: it should be more expensive than Beo5
I do hope it will be a Bluetooth remote control, that's the only way to get fast & easy 2-way communication nowadays, but since there are no Bluetooth enabled audio-video masters in the present range, I'm ..dubious..
I would love it to look like the prototypes from Avus..
Reunion Island is greeting you!
