Hello All,
Have admired Bang & Olufsen design for quite some time, and just received a vintage Beomaster 1900-2 as a gift. The unit is in good cosmetic shape, just a few scratches on the aluminum that I will try to clean up.
I was hoping that someone on the boards could help me out with the unit. It came with 2 sets of speaker connectors which are 2 plug weird connection. They are spliced to some regular speaker wire. It also came with a 5 pin DIN to RCA I think, very corroded RCA connectors. It is odd that the DIN has 2 sets of RCA inputs leading out of the 1 DIN... Is this normal?
I connected 2 speakers I have that are 8 ohm rated. I plugged in a stereo headphone to RCA to hook up my iPod. Plugged power on the unit. standby light lit up. selected Tape input, the "T" lit up, and I heard a buzzing sound on the left speakerand could turn the volume down to get it to stop, but I could not hear my ipod. I then hit the FM1 button (no FM antenna came with unit) and could hear the noise sound on both speakers very clearly, with no buzz / hum sound.
The FM1 light did not light up, nor the bass, treble or balance. What problem is that?
What type of FM antenna do I need? Should I get a DIN to RCA to listen to my iPod?
Could the Buzz sound on the left channel while in Tape mode, come from a bad connection of the corroded RCA inputs on the DIN to RCA connector I have?
Any help is appreciated, I am a novice, and dont have much knowledge of vintage electronics, but love this 1900 and would like to get it working properly, I am a collector of great design and specifically mid century modern.
Thanks,
Adam
