Latest post 02-13-2010 3:50 PM by joeyboygolf. 3 replies.
Page 1 of 1 (4 items)
  • 02-13-2010 12:55 PM
    Beocentre 9000
    Hi...
    I am new to this site.  I bought a B&O Beocentre 9000 recently and love it.  I have been searching the net for the Beogram 9000...but am having difficulty finding one.  Are they a rare item?...can I use another Beogram in it's place...and if so, what is the best model to go with.  Thanks and I appreciate any answers.
    Steve
  • 02-13-2010 1:47 PM In reply to
    Re: Beocentre 9000
    Personally, I don't believe that the Beogram 9000 is a good cosmetic match so I would look at others.
    You can use any turntable that does NOT have a built in RIAA pre-amp.  See here
    http://www.beoworld.org/article_view.asp?id=67
    Regards Graham
  • 02-13-2010 1:57 PM In reply to
    Re: Beocentre 9000
    Thanks for the reply and input.  As I mentioned, I am new to being a B & O owner...what Beogram would you recommend at the best to go along with my beocentre 9000?
  • 02-13-2010 3:50 PM In reply to
    Re: Beocentre 9000
    If you fancy a tangential deck then the best value for money and a good cosmetic match would be a Beogram 3000 or 3300.
    Ensure that the stylus/cartridge is good (Should have MMC4 ) because they are hellish expensive to replace.
    Regards Graham
