Latest post 03-01-2010 9:33 AM by nitro2. 5 replies.
Page 1 of 1 (6 items)
  • 02-13-2010 9:28 AM
    • nitro2
    • Top 500 Contributor
    • Joined on 10-08-2008
    • belgium
    • Posts 84
    help needed with the reviving of a BM7000 external ir "sensor "
    Who can helkp me ??
    i got a master 7000 without the external ir-sensor connector .....................
    so cable found ( thanks gregg ) and shipped , sensor found ( thanks to ebay ) , but it is not working.
    i found all bm7000 connections and schematics concerning this modification , but cannot find a schematic of the "sensor " itself.
    Who can help me ??
    nitro2
  • 02-13-2010 10:52 AM In reply to
    • nitro2
    • belgium
    • Posts 84
    Re: help needed with the reviving of a BM7000 external ir "sensor "
    Thanks for your help ,
    In fact i was looking for the schematics of the complete device .
    see picture .
    Is there someone who has the installation description for this "sensor"-kit ( 8087018 )
    nitro2
  • 02-13-2010 1:05 PM In reply to
    Looks the same as the sensor for the Beomaster 5500?
  • 02-13-2010 1:28 PM In reply to
    • nitro2
    • belgium
    • Posts 84
    Most likely it is all the same sensor 5500 , 6500 and 7000 .
    The connection on the bm has been dropped on the 6500 and 7000 , but was available as an upgrade-kit for these units.
    i have put in the cable conn 98 on the processor pcb , and measured the 4 lines and do think there is smoething wrong .
    so now it is time to measure , ...................
    If someone has the schematics , that would be of great help.
    nitro2
    nitro2
  • 03-01-2010 9:33 AM In reply to
    • nitro2
    • belgium
    • Posts 84
    Hi forum ,
    The sensor is working , with help of nick who handed over valuable information.
    the thing to keep in mind is , that the 8 volt supply to the external sensor has to be wired-in , CP1 has to be connected to 8 volt otherwise there is no supply going into the sensor.
    8 volt can be found on the display/front pcb pin 4 of connector P11 .
    sensor schematics are here ;
    nitro2
