Dear all,
I have spent several hours (nights) studying the existing posts about miscellaneous display problems regarding the Penta. Yet none has provided the solution. I have a pair of Beolab Penta MkII's, acquired from their first owner (superb overall condition!) One of the displays is working, although fairly dim, the other one is out. So far I have tried the following to fix the problem
- Cables: Powerlink MkII, all pins connected and checked ok
- Also tried to connect the cables vice versa and into different sockets and sources
- Audio/video switch set properly
- Dismantled the display units out of their sockets and swapped them vice versa (both units function properly in one speaker)
- Dismantled the amplifier and checked the Powerlink (Datalink) connection between amplifier and speaker
Still no luck. Does anyone have anymore ideas to get the display fixed?
Kind Regards!
