Latest post 02-10-2010 5:18 AM by tournedos. 1 replies.
Page 1 of 1 (2 items)
  • 02-10-2010 4:54 AM
    • lausvi
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Helsinki - Finland
    • Posts 498
    • Gold Member
    BM4500 + non-B&O subwoofer
    (I know subwoofer issues have been discussed earlier but I couldn't find one to answer my problem).
    I am working as an IT- and AV-support in a school. That way I have some nice gadgets lying around and I try to make use of them. In my office I have a Beomaster 4500 + Beogram CD4500 with Beovox 3000 flat-panel speakers Embarrassed The speakers are fine but they lack in bass as of their size and type.
    I have an excellent Genelec active subfoower available so I'd like to connect it to the system. I have done it by taking the signal from the powerlink socket (combining L and R-channels) but this causes the main speakers to work in mono, too! I can run the system fine if I only take one channel to the sub (listening to it right now, sounds absolutely fantastic!) but I guess it's should have both channels there. Any ideas?
    Bang & Olufsen - The art of controlling sound, picture and light
  • 02-10-2010 5:18 AM In reply to
    Re: BM4500 + non-B&O subwoofer
    Yes, it will play in mono as you are essentially shorting the channels together after the preamp... try something like this (I use the same CAD program as Jaff).
    -mika
