Latest post 02-10-2010 6:43 PM by Stan. 2 replies.
Page 1 of 1 (3 items)
  • 02-10-2010 3:07 AM
    • Alain
    • Not Ranked
    • Joined on 10-22-2009
    • Bierbeek, Belgium
    • Posts 9
    How to store numbered positions or colored lists?
    The BS5 manual mentions that a radio station can be added to a colored list or numbered position.
    Procedure to follow is:
    1. Select station
    2. Press and hold GO-button
    3. Select with the wheel
    4. Release the GO-button
    When I follow this, in step 3, when I turn the wheel, the first letter of the station under focus appears to the left of the station name.  Wherever I release the GO-button, nothing happens.  There is no way to select a color or a numbered position.  I also tried to select FAVORITES first, then press and hold GO and select a number, but that doesn't work either.
    Has anyone been able to store a radio station in a numbered position, and how ?
    My software is up-to-date.
    Filed under: ,
  • 02-10-2010 7:38 AM In reply to
    • steph
    • Top 100 Contributor
    • Joined on 04-16-2007
    • France
    • Posts 612
    Re: How to store numbered positions or colored lists?
    Strange,
    the procedure is OK for me.
    I hold the GO-button, select a number for instance in the favorites and release the button.
    After that, in the favorites menu, i can see the name of the radio next to the choosen number.
  • 02-10-2010 6:43 PM In reply to
    • Stan
    • Top 150 Contributor
    • Joined on 04-17-2007
    • Posts 593
    • Gold Member
    When you press GO at step 2, the name of the station should move to the left, and the screen should display ADD TO after the station name and be positioned at the 1st numbered position.  You then turn the wheel to select the colored list or numbered position and release GO.
    If this isn't working, then I'm not sure what to say...  reboot?
    Stan
