Latest post 06-20-2007 4:19 AM by Peter. 3 replies.
Page 1 of 1 (4 items)
  • 06-18-2007 4:00 PM
    beogram 4004 7 pin din connections
    Does anyone know the pin connections for the yellow and blue cables I can not find a circuit in the manual section for this unit.
  • 06-18-2007 4:34 PM In reply to
    Re: beogram 4004 7 pin din connections
    Blue goes to pin 7 and yellow to pin 6, Looking from the soldering side, with the gap at the top, pin 7 is the one top left and pin 6 top right. (Just pulled my plug apart!!) Laughing
  • 06-19-2007 5:13 PM In reply to
    Thank you for your help. I have now wired the plug up correctly but have a strange effect using a Beocentre 9000 as an amp. The deck will turn off when you select any source but not go into play from the remote. It will however go into play when you plug the din plug in. Suspect I am using the wrong amp.
    Regards
    Richard
  • 06-20-2007 4:19 AM In reply to
    The remote bit will only really work with a Beomaster 2400. For all others I would remove the extra pins and use it manually.It was a precursor to Datalink and is not compatible.
