Latest post 02-06-2010 5:47 AM by Ehlerz. 5 replies.
Page 1 of 1 (6 items)
  • 02-05-2010 8:08 AM
    Synchronization problem with BV 8-40
    Dear All,
    Since a few months I own a BV 8-40 to which I've connected a PS3 through HDMI and scart. I'm using this setup to stream my music. In itself this is a very neat solution, there is however one major setback. If I play music in the livingroom and the kitchen (where I have a Beolab 3500) there is a synchronisation issue between the both. I suspect that the decoder in the BV 8 is taking more time to process than the analog signal through the BL 3500. The difference is only a few milliseconds, but very annoying. My B&O dealer can't help me, so I am looking for suggestions.
    thanks in advance for any help given
  • 02-05-2010 8:32 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: Synchronization problem with BV 8-40
    As far as I remember: no solution available, check other threads on this forum (audio delay)
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 02-05-2010 12:00 PM In reply to
    This is in my opinion a HUGGGGGEEEEEEE problem as i have 5 rooms linked close to each other, and often play in every room simultaneously. Only solution would be to delay the Masterlinksignals accordingly which as i am told, is not possible..  SO why B&O has not thought about this is amazing. Masterlink is a huge B&O asset, and with everything being digitalized, it now does not work anymore.
    SO untill B&O introduce their new masterlink solution, and we have to rewire everything in our setup, i guess we and our +40.000$ system will just have to live with it...:-(
    What surprises me however, is that also analoge outputs connected to my main room tv is delayed in linkrooms. Why is this?
    If i connect my Macbook Pro to the red/white Camera input on the side of my BV 7-40 MK IV, signals are delayed aswell. If i connect my macbook to the AUX on my BS3000, the signal is NOT delayed. Can anyone explain this?
    /ehlerz
    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
  • 02-05-2010 5:06 PM In reply to
    • Nobsi
    • Not Ranked
    • Joined on 01-11-2010
    • Posts 6
    • Silver Member
    Hi there,
    I am not sure this solution is viable with beovision 8-40, but I had a sound delay issue with my beovision 7-40 MKIII. In the service menu you will find sound adjustments and the default value for sound delay was 90ms. I simply set that back to 0ms and I have a perfectly synchronized sound now.
    Regards
  • 02-05-2010 5:47 PM In reply to
    There is another thread that describes a device to overcome the delay issue.
    Cheers,
    Frank
  • 02-06-2010 5:47 AM In reply to
    Nobsi:
    Hi there,
    Regards
    Hi Nobsi
    That is correct, but the default sound delay is there for a reason. If you set this to zero, all your linkrooms will be in synch, but your mainroom will not when watching say Bluray. So on my MK IV i have to choose which on i can live with best. Not being able to watch anything connected with HDMI on my mainroom tv AND having sound in every room, or vice versa...
    /Ehlerz
