Latest post 02-05-2010 8:31 AM by Razlaw. 1 replies.
Page 1 of 1 (2 items)
  • 02-05-2010 7:13 AM
    • Seanie_230
    • Top 75 Contributor
    • Joined on 04-20-2007
    • Milton Keynes, England
    • Posts 962
    • Gold Member
    BV7 MK3 Sky HD PUC & Apple TV Puc
    Hello all
    has anyone else noticed that if you have a sky hd box and apple tv connected to the BV7 and use the PUC that when you use sky it seems to send commands to the apple tv also.
    this was mentioned by someone before but i had not experanced it.
    what would cause this and are B&o aware?
    Beovision 7 MKIV (Blu Ray)
    Beolab 9
    Beolab 6000
    Beo 4
    Beocenter 9300
    Apple TV
    SKY HD
    Optoma HD65 Projector
    Lintronic TT455-RT-238
    Beovision 3 MKII
  • 02-05-2010 8:31 AM In reply to
    Re: BV7 MK3 Sky HD PUC & Apple TV Puc
    As I am in the USA I have no experience with sky. However, I had problems with the Apple PUC in that whenever I would use another source it would at times send a signal to the Apple TV. It was basically impossible to leave Apple TV in standby as operating other sources (turning them off if I remember correctly) would turn the Apple TV back on.
    I solved the problem by using the puc for a Samsung t-351 and then using the remote learning function of the Apple TV. It works just as the Apple PUC other than I used Green for what would be Exit in the Apple puc. I had difficulty getting the Apple TV to learn the Exit command. Recently I noticed that there are 9 other commands available on Apple TV for learning remotes, such as skip forward etc. I again used the learning function and was able to get the numbers 1-9 on the Beo 4 to control these. Dealer is in the process of programming a Beo 5 for me. He is going to try to put a screen on the Beo 5 with the 9 additional Apple TV commands labeled by function with the Beo 5 sending the signal for numbers 1-9 so I do not need to remember which number does which function.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
