Latest post 03-17-2010 9:21 AM by Silou. 40 replies.
Page 2 of 2 (41 items) < Previous 1 2
  • 02-09-2010 2:54 AM In reply to
    Re: Beo5 CT3.57
    You are correct, check HERE
    Regards Keith....
  • 02-09-2010 2:56 AM In reply to
    Re: Beo5 CT3.57
    My Bang & Olufsen....
    • BeoCenter 2 DAB/DVD mk.II
    • BeoVision 7-40 DVD mk.III
    • BeoLab Penta mk.III
    • BeoLab 4000 icepower
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beo 4 mk.I & mk.III
    • Beocom 6000
    • A8 Earphones
  • 02-09-2010 8:20 AM In reply to
    Re: Beo5 CT3.57
    A new version already? That is fast!
    Is there a major bug in version 3.57?
    Keith, do you know the difference between 3.57 and 3.59?
    Piet
  • 02-09-2010 10:20 AM In reply to
    Re: Beo5 CT3.57
    The difference between 3.57 and 3.59:
    This error is now solved in 3.59: Speakers added in old configurations are hidden.
  • 02-11-2010 11:18 AM In reply to
    Re: Beo5 CT3.57
    BEOCET:
    Is it possible to download Beo5 CT3.59 some places on the net!
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beocom 6000
    • A8 Earphones
  • 02-11-2010 11:31 AM In reply to
    Re: Beo5 CT3.57
    Det ved jeg ikke
  • 03-06-2010 12:18 PM In reply to
    Re: Beo5 CT3.57
    Well the Page format is Great news ;) Finally i can put some 1x1 pages or 2x2 ! Really nice ! :)
  • 03-10-2010 8:27 AM In reply to
    • dueno
    • Top 500 Contributor
    • Joined on 04-29-2007
    • bordeaux
    • Posts 147
    Re: Beo5 CT3.57
    i can't modify the screen type (4x4,3x3,2x2,.....) for the page i create and for the preformated page.
    i have the beo5 CT 3.57
    any idea?
    never explain never complain
  • 03-11-2010 4:56 AM In reply to
    Re: Beo5 CT3.57
    You need to create a completely free level.
    This can be done by creating a new button and then enable the submenu option.
    When you enter the new sub menu, the screen type selection is enabled until you place a button on that menu.
    If you want to change the screen type for an existing level, you need to drag all pressent buttons to the clip board, then change the screen type and drag the buttons back. Be carefull with this, you may have serialisation errors depending where in the configuration you do this.
  • 03-11-2010 8:29 AM In reply to
    • dueno
    • bordeaux
    • Posts 147
    Re: Beo5 CT3.57
    ok
    nown it works
    and it's very nice
  • 03-16-2010 8:57 AM In reply to
    • dueno
    • bordeaux
    • Posts 147
    Re: Beo5 CT3.57
  • 03-16-2010 8:58 AM In reply to
    • dueno
    • bordeaux
    • Posts 147
    Re: Beo5 CT3.57
    • dueno
    • bordeaux
    • Posts 147
    Re: Beo5 CT3.57
  • 03-16-2010 2:00 PM In reply to
    Re: Beo5 CT3.57
    Nice !
    Those buttons looks fantastic with this screen type, have you created them yourself or do you have a good source on the Net?
    By the way, the optimal resolution is 90 by 90 pixels for this screen type.
    Have you managed to continue this great look on the other pages? I could imagine that this is a tough task...
  • 03-16-2010 8:30 PM In reply to
    • dueno
    • bordeaux
    • Posts 147
    Re: Beo5 CT3.57
    I have do this icons by a psd file i have found on the net, just have to do the brush for each icon and change the color.
    I have just done this for the source
    http://www.itechster.com/2008/04/29/purple-gel-button-apple-iphone-style/
  • 03-17-2010 9:21 AM In reply to
    • Silou
    • Joined on 08-10-2007
    • Switzerland
    • Posts 241
    • Gold Member
    Re: Beo5 CT3.57
    Nice, joli boulot dueno!
