Can anyone advise me how to replace the tuning cord. I have assumed the AM module needs removing and at first sight this looks easy but I see complications. There is a multi-way connector and four screws that look as if they release the whole unit. There are however three leads that disappear under the cover at the rear of the main panel. These seem to be soldered to the pcb of the AM module that would prevent the whole module being removed.
Is it required to replace the cord with it still attached to the set or do these leads have connectors somewhere? I am reluctant to unsolder them but it looks as if refitting a cord will be easier with the module removed.
Thanks in anticipation
John.
