Hi!
I`ve installed the rebl file from beoworld on my beo5. The problem is, that this file is only working as a accessories, and not signed to dvd on my beovision10. So I could not place the rebl ir converter behind my television. It must be somewhere in Visibility.
My 10-40 is flashed with the rebl ir table by bang&olufsen.
If I`m using my beo4 the 10-40 is receiving the remote commands and transfer them with the STB-IR cable from Puc2 to the rebl converter which is placed hidden behind my 10-40.
But i prefer to use the beo5 and beo5 file. Either easier to use and with switching of command.
Is there anywhere a file (or instructions for beginners) with all commands, available for beo5 and rebl.
Thank you in advance and regards from germany
Frank
