1st March February 2012
Latest post 02-17-2010 6:33 AM by andy. 20 replies.
02-03-2010 8:28 AM
andy
- Joined on 04-18-2007
- weston-super(!)-mare
- Posts 123
Hello...
i bought my first Mac at the weekend, a Mini along with an IPOD Touch on wicj i have downloaded the "remote" software.
So, in my lounge i have a new BV732 with a Mini connect, and it all works fine, i can control itunes throught the Touch no worries ( but no RADIO on the list ??..should it be there ?)
Anyway..when i go into the kitchen and turn my Beolab2000 on by the end button it turns on and i can hear what ever i am listening to in the main roon
now......
in the bedroom i have an old avant with some Lab6000`s.....i cannot for the life of me get this to turn on with the Mini as the source....
i havent yet investigated video as yet btw...thats next...but how do i turn my avant on to the pc source ?.....
i am a computer numpty btw !...lol
andy
francis
- Joined on 04-16-2007
- Münster, Germany
- Posts 108
Jandyt:
Hi Andy, I'm not sure, but I think the Beovision must be NRADIO/NMUSIC compliant to work, and I don't think the Avant is. If I'm wrong, someone will soon correct me, I'm sure. Hope you are well
Andy.
Yes, I have to correct you: in a setup like Andy's, the TV has not to be NMusic compliant. I was using a pretty much similar setup: Mac mini connected to a BV 7-32, in one link room a BL 2000 and in a second link room a MX4002, all connected via masterlink. I could hear the music from iTunes running on my Mac via BL 2000 and MX4002, as the sound signal is simply distributed per masterlink like sound from any other source. Unfortunately I have changed my setup and don't use the MX any longer, so I can't figure out experimentally what might be wrong with Andy's setup
|BV 7-32|BL 7-1|Ouverture|BL Penta|BL 6000|BL 2000|Beocom 6000|Beotalk 1200|MX 4000|Beoport|Beo4|Beo5|A8|A9|
BEOCET
- Joined on 02-10-2009
- Posts 24
Hey Andy
What V.OPT (video option) is your Avant set to?
Make sure the Avant is set to V.OPT : 6
andy
- Posts 123
i cannot rememeber what its set to to be fair...but i do know that everythinf else, link wise works ok...ouverture (not in same room as tv btw!), tv..
if i added n/music to the remote ?..might that work ??
andy
andy
- Posts 123
peter
its a flat screen, so adding n/music should do it ?
i have to say i am impressed with the Mac thing....
on my ipod touch btw i cannot get the list of internet radios stations on it....Radio is not even in the list of options on itunes in the touch..am i missing something ?
andy
burantek
- Joined on 05-04-2007
- SE USA
- Posts 6,214
andy: on my ipod touch btw i cannot get the list of internet radios stations on it....Radio is not even in the list of options on itunes in the touch..am i missing something ?
Andy,
In iTunes...
1.) Add a playlist titled "RADIO", or "RADIO REGGAE" or whatever...
2.) Drag and drop your preferred stations to their respective playlists.
3.) Enjoy!
BEOCET
- Posts 24
Hey Andy
I have to say that adding N/music on your Beo4/Beo5 remote makes no sound available from your mac mini on your "avant bedroom".
If the Avant (in OPTION 6) don't respond to your PC command, then you should try to change the command/Input name on your BV7 to V.AUX.
And then give the Avant the V.aux command.
If you want to have picture from the mac mini on the Avant you need to connect one extra analog video cable (CVBS/Composite) to the BV7 from the mac mini. And I don't think it's possible because the mac mini only has Mini-dvi as Picture output.
PhilLondon
- London
- Posts 2,545
andy:
As your Mac mini is recent, you've connected it to the BV7 using HDMI or DVI.
Beovisions are not able to distribute digital video or digital sound. That is why you cannot display anything on the Avant.
A possible solution is to find a mini-displayport to VGA cable, and then a VGA to Composite converter. Then connect the composite cable along with analog sound to the scart of the BV7.
You can keep the DVI or HDMI cable. This connection should come in addition, so you can enjoy HD on you BV7, but in that way it will use the SD signal.
I have not tested the solution but that's the theory.
BEOCET
- Posts 24
Hello again Andy
Are you able to watch DVD from BV7 on your Avant?
andy
- Posts 123
couple of answers now i have got that pesky work off my desk...lol
mini mac is brand new so actually has 2 video outs...
avant is a later flat tube
have tried dvd ( BV7 is non-dvd version) with my external sony and never got it to work, but only tried it once and didnt put too much effort in
so n/music may or may not work it seems from the replies...
another question...if i get the sound to my avant...i presume i dont need to leave the BV7 "on", it will just go into stand-by
also.....BV7 question....is there a "picture mute" ??
also.....lol..while i am here...my normal ipod has all my music on ..but recorded from a pc...how do i sync this back to the mini mac ?....
andy
BEOCET
- Posts 24
If you want to view picture on your Avant from video-sources connected to BV7. You first need a RF-linkamplifier.
After you have a RF-linkamplifier installed you need to control the video-source with PUC/STB control on BV7. And Remember what Phillondon said about digital video distribution is NOT POSSIBLE on the link, you need the extra analog video signal from the videosource.
BEOCET
- Posts 24
If you have a Beo5 remote you can add a button white the "p.mute" command.
If you have a beo4 remote you can add the "p.mute" command in the list.
andy
- Posts 123
first trail unsuccessful...adding n.music and r.music to the avant produced........nothing !
as off yet i dont want ( or know how to!) change it to v.aux
any bright ideas?
what op should the avant be in ??...it is connected to a ouverture and a BV7..
andy
andy
- Posts 123
ok...
so, adding N.Music, N.Radio to the Avant produced nothing
i changed PC to v.Aux, (DVD2 in the AV4 menu on the 7)..added v.aux to thr avant remote..nothing !
i have the mac into VGA and sound into the 2 phono sockets
what about using optical out ( same jack as headphone out which i cannot think how it works but the manual says head[hone out/potical out)..and in to the Sdif (?) which id digital in........can i distribute digtal sound ?( not bothered about the mini mac picture btw)
its getting on my wick now !...lol
Peter ?....have you got this working ?
andy
andy
- Posts 123
problem solved.....bought airport and stuffed it in the ouverture !
leads from sounds heavenly ! thank you !
andy
Page 1 of 1 (21 items)
