Latest post 02-03-2010 6:46 AM by BarryNI. 3 replies.
Page 1 of 1 (4 items)
  • 02-02-2010 11:04 AM
    BEO 6000 active speakers with non B & O kit
    I wish to use my BEO 6000 speakers with a standard pre amp.  Whilst the connection is not a problem beolink to RCA, where do I get the trigger to bring the speakers out of standby?
  • 02-02-2010 5:35 PM In reply to
    • beoblok
    • Top 500 Contributor
    • Joined on 03-19-2008
    • Finland
    • Posts 80
    Re: BEO 6000 active speakers with non B & O kit
    I think they can be fed from your amplifier via B&O attenuators, so your BL6000's are then activated by the audio input...
    Maybe check the "workbench" part of the forum.
    Hope this helps
  • 02-02-2010 5:40 PM In reply to
    They can be operated straight from a line level output (with controlled volume). Just connect your signal to the RCA input and turn the input switch to "LINE". The speakers will turn on automatically when they receive a signal, and turn off automatically after it has been gone for a few minutes.
    -mika
  • 02-03-2010 6:46 AM In reply to
    Many thanks from both contributors, for solving the problem.
