Latest post 02-01-2010 9:06 AM by Stonk. 4 replies.
Page 1 of 1 (5 items)
  • 02-01-2010 1:30 AM
    Beocentre 9000 CD plastic cap
    Hello,
    My name is Ian Ellis & I have recently had my Beocentre 9000, which I have owned for approx 20 years, in for repair in Melbourne Australia.
    The repairer could not provide the small part required to repair the CD player.
    The CD player has a black tapered plastic cap that holds the spring on the centre shaft.
    The plastic cap has broken.
    Does anyone have have a replacement plastic cap and the spring if possible? A cap & spring from a discarded unit would be fine.
    I would greatly appreciate assistance as I have a huge attachment to my Beocentre 9000 and am desperately missing my music!
     Thank you, Ian.
  • 02-01-2010 4:28 AM In reply to
    Re: Beocentre 9000 CD plastic cap
    I am afraid that these are as rare as hens teeth and their failure has caused many a good BC9000 to be consigned to the skip!
    Except!!!!!!!!
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=120523114071&ssPageName=STRK:MEWAX:IT
    Regards Graham
  • 02-01-2010 4:50 AM In reply to
    • Stonk
    • Top 50 Contributor
    • Joined on 04-16-2007
    • Marlow, Bucks, UK
    • Posts 1,688
    Just out of interest...
    I've never seen this part in situ but I can see from the link that Graham posted the bag contains a number of bits - if only the plastic cap was re manufacturered would this solve the problem and you could use the original spring etc?
    Steve
    If you think nobody cares, try missing a couple of payments.
  • 02-01-2010 8:19 AM In reply to
    Stonk:
    Steve
    Yes, in 99% of cases.
    The kit, from memory, comprises the now infamous plastic widget, a new spring with a plastic ring that fits inside it and a replacement circle of non slip sticky backed plastic to stick on the turntable and better grip the CD.
    As long as the spring is retained by the user, it can be re-used. The danger is that they get binned with the broken widget!!!
    Regards Graham
  • 02-01-2010 9:06 AM In reply to
    • Stonk
    • Marlow, Bucks, UK
    • Posts 1,688
    Thanks. I have no real vested interest in creating a replacement however I do like to play while my wife watches Celebrity Dancing On Opera et al but do need an original to work from.
    I've sort of succeeded in doing the same with Beolit sliding knobs.
