Latest post 01-29-2010 12:38 PM by Ehlerz. 1 replies.
Page 1 of 1 (2 items)
  • 01-29-2010 12:15 PM
    BS 9000 and Mainroom - linkroom audio question
    Hi All
    I am currently considering upgrading my BS3000 to a BS9000, as i have BL5´s and would like the ability to connect them to the digital audio out on BS9000. I have a questions in this matter.
    I currently have my BS3000 with AUX connected to an airport express so i can play music in all linkrooms from my macbook pro. This works like a charm with NO delays across rooms. The question is, if i hook up the BS9000 the same way and use AUX, will the main room play through digital or masterlink?(speakers also hooked up with powerlink to BV 7-40), and if digital, will there be any delay in the linkrooms ??
    I ask because i often have all linkrooms playing simultaneously when i am having a party, and would like to continue having this opportunity, while ALSO hooking my Bl5´s up digital. Two linkrooms are not separated by a door so it is perfectly possible to hear any even minor delay.
    Does the BS9000 only use the digital connection while playing CD´s, as it is not possible to connect anything digital to it??
    Thanks in advance.
    /Ehlerz
    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
  • 01-29-2010 12:38 PM In reply to
    Re: BS 9000 and Mainroom - linkroom audio question
    Ups...posted i forkerte forum :-)
    Moderator, please delete this post in the scandinavian forum.
