Latest post 01-30-2010 1:15 AM by auclutch. 2 replies.
Page 1 of 1 (3 items)
  • 01-29-2010 11:13 AM
    • root
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Posts 163
    • Silver Member
    beocom 2 settings
    I have a Beocom2 phone (MK1 from 2003) which hasn't been used for a while.
    the battery was flat so I replaced it. Now I wanted to register it to the base unit (old version) so I chose 'settings' in the menu and there should be 'advanced settings' and then 'register to base' - but the strange thing is that I there is no such point 'advanced settings' it's just not there.
    what should i do now???
    Marcel
  • 01-29-2010 4:38 PM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Re: beocom 2 settings
    Hi
    You could try a factory re set of the BeoCom2 handset.
    9 # 9 # 9 * int
    This takes you into a menu that you can scroll down to a re set option for the handset
    Opman
  • 01-30-2010 1:15 AM In reply to
    yes, to reset, I did the same thing yesterday.  except for int, I pressed hold
    BS1 x 2, BS 3, BS4, BS2000 x 3, BS2300, BS4000, BS9000, BL4, BL 4000 x 2, BL8000 x 2, BL2500 x 2, BL2000, Beocom 2, Beocom 6000 x 4, Beocom 1401 x 4, Beocom 1600 x 2, Beocom 2500 x 4, Beotalk 1200, A9 Keyring, Beo4 x 8, Beotime, Bottle Opener
    2011 Wish List: BL3500, BL6000, BL5, BL9, active link, BS5, Beo5
