Hi Folks,
My father-in-law has a BC900 which he loves. It's been repaired a few times already and this time the shop says it needs a new power supply and a few capacitors (again). The left side of the cover is a bit loose, but you wouldn't notice unless you accidentally pulled up on it.
So, his options are to put another $300 to $600 into it, or, and very sadly, say goodbye to it.
If he does say goodbye, which he is somewhat reluctantly leaning towards, would this site be a place to find a new home for it, either for parts (remote, CD parts, etc.)? Or should we try eBay or Criagslist type sites? I'd hate to take it to an electronics recycle place if it can be of use to someone and possibly get my father-in-law a few $ towards a replacement.
Donald
