Latest post 01-29-2010 2:48 AM by zazouzt. 6 replies.
Page 1 of 1 (7 items)
  • 01-25-2010 8:28 AM
    • zazouzt
    • Top 500 Contributor
    • Joined on 04-17-2007
    • near Strasbourg/France
    • Posts 123
    Beomaster 5000 problem
    I installed an MCL2AV but forgot to disconnect the Din Plugs from the beomaster 5000, and now the beomaster doesn't power up.
    What can be wrong ?    I controled the fuse but it's ok.
    Zazou
  • 01-25-2010 9:06 PM In reply to
    Re: Beomaster 5000 problem
    What DIN plugs did you connect ?
    Beoworld product section says nothing about the BM 5000 being supported by this unit:
    http://www.beoworld.org/prod_details.asp?pid=978
    Similarly beocentral says this unit came after the end of the BM 5000 product (superseded by the BM 5500):
    http://www.beocentral.com/products/mcl2av
    However this Beoworld thread may provide some insights:
    http://forum.beoworld.org/forums/p/26317/204223.aspx
    Also don't forget Beotech as a resource:
    http://www.beoworld.org/beotech/mclconn2.htm
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 01-25-2010 9:08 PM In reply to
    I initially replied to your post with the following proper working links, however my post went into moderation (the too many links rule) so I am doing a re-post ....
  • 01-26-2010 2:30 AM In reply to
    • zazouzt
    • Posts 123
    The cable between the Beomaster and the Mcl2av  has on one side Din plugs with 3 pins each, and on the other side the wires are free to connect to the Mcl2av.
    Zazou
  • 01-27-2010 7:25 AM In reply to
    • zazouzt
    • Posts 123
    It's only to refresh.
    See the answer below.
    Zazou
  • 01-27-2010 7:37 AM In reply to
    Do you get the red standby dot? If not, the worst case scenario is that the CPU was damaged by static electricity or some kind of voltage spike when you played with the connectors. The BM5000 unfortunately has very little internal protection for this. If this happened, the only way to fix it is to get a new processor chip (or preferably the complete CPU module) from a parts unit...
    Could be also something less drastic, that just happened to occur at the same time. But there's no way of knowing without investigation, starting from the supply voltages, and replacing the caps in the CPU module. Faulty caps and unstable supply lines might prevent the processor from starting up.
    -mika
  • 01-29-2010 2:48 AM In reply to
    • zazouzt
    • Posts 123
    Thanks for your reply.
    It's amazing that those things can arrive when the beomaster is not in fonction.
    I had the red dot, but after  playing with the connectors, it was gone.
    I'll try to control what i can, but i'm not very bright.
    zazou
