My 7-55 has some controller lag when using xbox games.
Previously had a 7-40 without problems so I'm assuming its todo with the 120hz.
Tried turning off movie mode, no difference.
Any ideas ?
John
The answer is to have it on the PC menu, then the box doesn't do any signal processing.
How's your X-box connected? Mine is connect with a component-cable to a bv 10, but also with the tv set to pc, I still experience HD-lag.
