Latest post 01-23-2010 2:03 PM by dbxdx5. 7 replies.
Page 1 of 1 (8 items)
  • 01-22-2010 9:26 AM
    Rebuilt MMC2--worth it?
    Right now I have a rebuilt MMC5 on my Beogram 1800 (Axel did the rebuild). I like the sound, but of course now I wonder how much better things can get with a better cartridge. I've read some of the conversations about the sound of Axel's rebuild vs. the SMMCs of Sound-Smith, but I'd like to know if anyone has had experience with a rebuilt MMC2 specifically, and whether it would be worth the investment compared to going with, say, a Sound-Smith SMMC3.
  • 01-22-2010 11:11 AM In reply to
    Re: Rebuilt MMC2--worth it?
    I have a rebuilt MMC2 courtesy of Axel and it is superb - just as good as the original. Very good value for money as well. You can of course make any of the MMC range into a 2 as the only difference in these cartridges is the cantilever and diamond and this is changed.
  • 01-22-2010 3:42 PM In reply to
    Agree with Peter re the Axel MMC2
    Regards Graham
  • 01-22-2010 5:47 PM In reply to
    • 9 LEE
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Moderator - UK
    • Posts 5,223
    Does Axel do MMC1's - if so, how much does he charge?
    Lee
  • 01-23-2010 7:17 AM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    I would imagine it would be the same as a MMC2 Lee. IIRC, MMC1's were simply handpicked MMC2's. I'm sure Peter et al will correct me if I'm wrong!!!!Hmm
    Chris.
  • 01-23-2010 7:25 AM In reply to
    I always thought so too, but then noticed that Beocentral lists the effective tip mass of MMC1 as 0.25 g, vs the 0.3 grams of MMC2.
    I have no idea which property, smaller ETM or hand picking, would provide a bigger audible difference though!
    -mika
  • 01-23-2010 7:46 AM In reply to
    I do remember these coming out and being told that the 1 and 2 are identical but the 1 was the best performing as it was selected cartridges found on testing. However the catalogues do suggest that the ETM of the 1 is lower which would suggest a longer contact area. Either way, I doubt that an average Beogram would allow the differences to be heard! Of course neither of these cartridges had the lowest ETM - that prize went to the MMC6000 at 0.22.
  • 01-23-2010 2:03 PM In reply to
    Thanks for the feedback on my original post. I went ahead and ordered the MMC2 from Axel. I'll report back when it arrives and I've had a chance to break it in a little.
