Latest post 01-23-2010 2:28 PM by elephant. 16 replies.
Page 1 of 1 (17 items)
  • 01-21-2010 4:57 PM
    convenient way to send video from other sources to my kitchen tv ?
    I am putting a beovision 6 in my kitchen. The tv outlet is quite a bit away and also my computer so now:
    I know I can wirelessly send sound and remotesignals with for example beolink wireless or just by dragging cables directly through the rooms
    But if I want to for example control Plex stored in my computer room from kitchen tv, send tv-signals from tv-room to kitchen, send audio signals from both computer room and tv-room to kitchen, there´s gonna be a lot of cables, and since I dont plan on spending my whole life in this flat I would like a more smart solution before starting to drill out the walls.
    I like the look of the beolink wireless and if it did send video also I would gladly pay for 2 of these pairs just for look + quality + convenience, but now I guess I´ll have to go with some kind of mix of beolink wireless + something like these ugly philips plastic boxes with antennas on the rear to get both audio and media wirelessly to my kitchen tv right?
  • 01-21-2010 8:46 PM In reply to
    Re: convenient way to send video from other sources to my kitchen tv ?
    You are correct - the BeoLink Wireless 1 simply extends the Master Link connections across the air.  And as Master Link does not support video signals all you will get across the air is the audio associated with the video and the control signals to control it.
    Because my MacBook uses HDMI I do not get its PLEX video signal transmitted to my link rooms, but at least I can hear the audio and sort of blindly try to control it.
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 01-22-2010 8:26 AM In reply to
    hehe, using plex blindly, that seems convenient :) Really bang-olufsen luxury :)
    I recall somewhere that pc-version of beoport software did speak out at least the folder / playlist or categories you were at in the software. That would be nice, maybe it works in linkplayer main menu (as I read) but I did not hear anything speaken out (although I´ve not tested it in a link-room yet)
  • 01-22-2010 8:39 AM In reply to
    Yes, the Beoplayer had a lovely recorded female voice that would say "Connecting ..." or "Artists", but I dont think it announced the actual tracks - where as with LinkPlayer in iTunes mode pressing and hold (GO) while playing a song will result in a synthesised male voice announcing the track and the artist.
    I have been testing LinkPlayer MENU navigation from my link rooms.
  • 01-22-2010 12:18 PM In reply to
    Too bad then that my itunes get screwed up everytime I run linkplayer. It actually makes itunes crash everytime I run it after this, even though linkplayer is not running. Strange!
    I have pages Phil about this.
    Anyway. Back to sending video. If I have a beovision 6 with masterlink ability showing pc-screen how do I normally run picture and sound to be viewed simultaneously on a kitchen tv?
    Is it best to use the pc video out or beovision video out?
    What will the kitchen tv recognize that signal as? PC ?
  • 01-22-2010 3:48 PM In reply to
    The key is what video outputs does your PC have?
    And of those PV video outputs, which one have you already used to interface to the main BeoVision?
  • 01-22-2010 3:55 PM In reply to
    the beovision is using its dvi to connect to mini-dvi on macmini. Left is a minidisplay connector on macmini.
    So having the beovision on in pc/dvi mode showing pc screen and then output this to the other tv in kitchen via rf-out is not an option?
    I dont require top-notch video since I plan to use plex and have the fonts large for better clarity, real computer use will only be done in front of the mac
  • 01-22-2010 4:05 PM In reply to
    scanorama99:
    mini-dvi on macmini
    How old is the MacMini ... as in which version of MacMini?
    http://en.wikipedia.org/wiki/Mac_Mini
  • 01-22-2010 4:10 PM In reply to
    Hi:
    One option I am thinking about for myself is getting a set of thin clients and installing them next to my TVs (B&O crts). All you need do then in theory is install XP Pro or Server edition on your main PC and then set the thin clients up (they clearly need to be wireless enabled). Yes you will end up with larger plastic boxes than with the video senders you mention, but also much more functionality. With a wireless keyboard/mouse you can access all media stored on your main PC through the TV.
    I say in theory because I have not tried this myself so am unsure how easy it is to do - Microsoft networking in my experience is an absolute swine.
    Graham
  • 01-22-2010 4:16 PM In reply to
    It´s a march 2009 model 2.0ghz, 4gb ram, 256 meg videomemory, it has the small video connection not in use right now
    I googled "wireless dvi"
    and came up with this:
    http://addlogix.com/index.asp?MM=MM01&YY=YY1&m_id=38
    it seems they had this earlier but is now discontinued:
    http://www.superwarehouse.com/Mitsubishi_Wireless_Projector_Adapter/MA-WL-DVI/p/1487241
    Too bad since it looks much slimmer. Since I also plan to somehow hide this box behind the beovision hanging on the wall in the kitchen, it would be nice to have a small case. In the first link it looks like it also has some kind of ir-reciever and I was hoping I could find a solution that did not showcased a grey plastic box on my drawer under the tv just to make this work :)
  • 01-22-2010 4:31 PM In reply to
    I am currently using mac so I prefer a mac solution. For me I dont need to use the pc´s every detailed functions since i prefer ease of use in other rooms. Or I could just probably take my bluetooth keyboard and mouse if I want to my next room since it´s an apartment.
    So for me small-factor is good in other rooms :)
    this for example
    Wireless scart for multi-room use
    looks really nice and small :) I have seen it in several stores... and the salesman at my beostore told me that scart on bang olufsen screens are both video in AND out so in theory that would mean that I could place this in the back of each tv and send between different rooms (up to 30m) Big Smile
    b&o has left this section out for us so there is only one option it seems, apart from rf-cables, and that is to look for these other alternatives. Too bad since wireless video as I see it would be something that b&o should focus at least a little (?)
  • 01-22-2010 5:03 PM In reply to
    4 things ...
    ONE (2nd update)
    If the wikipedia entry is correct then you are in a better position than I was with my MacBook.
    • The DVI port was replaced with a mini-DVI port.
    • A mini-DVI to DVI-D adapter is included. A mini-DVI to VGA adapter is available.
    • A Mini DisplayPort was added in addition to the Mini-DVI port. This now allows the Mac Mini to work with the new 24" Apple LED cinema display directly and the 30" HD Cinema Display using a Mini DisplayPort to dual-link DVI adapter.
    • Both mini-DVI and Mini DisplayPort connections can be used concurrently for mirroring or extending.
    Apologies if I have mislead you with this paragraph:
    Using the mini-DVI to VGA would seem to give you the analogue signal you need to relaying to the second TV via an RF cable. You need to double check this mini-DVI port's VGA capability on Apple forums.
    I connected my wife's HP to the BV8 VGA port and I discovered that this signal is *NOT* relayed via the BV8 Active Antenna to link rooms.  I also tested her HP's S-Video output connection to the BV8 and thence to the link room, which worked, but all the colours were washed out to shades of grey.
    You could (depending upon distance) even look at a long DVI cable, I once had one in the UK that went about 10 metres.
    Which of these two ports did you say you are currently using for the main TV?
    TWO
    I think the wireless options need to be tested carefully.
    I have found BeoLink Wireless 1 to need careful placement. Initial I had it at spot A and had problems, then when my BV8 arrived I moved it to spot B and had more problems, based on another thread I have kept experimenting and now have it in spot C which is producing better results -- important to note that most of my wireless difficulties have come from kitchen equipment: microwave radiation and metal freezer cabinets, so given your target location is the kitchen this is something to consider.
    Also wireless extension for slide show presentations may have been design for a less demanding bandwidth that TV shows, whereas the wireless SCARTs seem to be more in the right design arena/area.
    THREE (1st update)
    I recently saw on an old thread a discussion about an HDMI to composite or component video converter - I think it was one of the Gefen products (quite a few BeoWorld members use and recommend Gefen).  This may be a route you could take.  If I can find the thread again I will post a pointer for you.
    http://www.gefen.com/index.jsp
    Examples of Gefen usage:
    http://forum.beoworld.org/forums/p/30775/246140.aspx#246140
    And here is the original thread I saw ...
    http://forum.beoworld.org/forums/p/17358/128537.aspx#128537
    FOUR
    If you were going down the distributed PC desktop path etc, I would think that an Apple TV might be more sensible if all you want to access is a collection of stored movies.  But if what you want is the desktop, applications, etc then a second MacMini with remote desk top access may be a more expensive option.
  • 01-22-2010 5:42 PM In reply to
    I use appleTV's and I set them up in a couple of hours and they have never given me any problems. They're both 40GB models (with atv flash) and stream everything from my NAS.  I did plug them both into ethernet now for sole reason of not wanting to have problems streaming 720p resolution content. Itouch to control them works ok. They're connected through component to older LCD and plasma screens.
  • 01-22-2010 7:54 PM In reply to
    cooldude:
    And I have seen various solutions for controlling other brands like apple tv with beo4 through i.e. beo4vrc, lintronic etc, but then You loose the ability to control this setup from other rooms right? Ok not if you put an extender in there but I feel that the idea with b&o is somewhat to have most parts integrated and controllable and I like to keep using my beo4 to the most if I can
  • 01-22-2010 9:30 PM In reply to
    Apologies, and please see my 2nd update to my earlier post - I could not get VGA to be propogated to a link room ....... Sad
  • 01-23-2010 7:46 AM In reply to
    ok, did You really see the picture on the first "sending" b&o screen? computers, you know, they dont always have the video out connectors active ;)
    Well best thing is to test various options and see what happens! I´ll try to avoid the "washed-out" version in Your tests :)
  • 01-23-2010 2:28 PM In reply to
    scanorama99:
    yes
    both VGA and S-Video displayed in 2 separate tests
    scanorama99:
    true, with windows you have to affect the properties of the desktop and extended the desktop to the second display (i.e. the BV8)
    with Mac OSX the BV8 is automatically recognised and activated (as a Beovision 8!!)
    Ed~209
