Latest post 02-06-2010 9:16 AM by B&Ola. 4 replies.
Page 1 of 1 (5 items)
  • 01-20-2010 9:22 PM
    SW Update on BV7-32 Type 9312 / Help Please !!!!
    Hello,
    I have a BV7-32 with the following serial numbers :
    Type: 9312
    Item: 1816681
    Serial: 1884XXXX
    I would like to update it in order to the latest firmware and PCM 2.0 over coax . My dealer is useless ! Is someone has the SW number that I should ask ? Any part number ?
    Thanks by advance,
    Mat
  • 01-21-2010 2:59 PM In reply to
    Re: SW Update on BV7-32 Type 9312 / Help Please !!!!
    Mat,
    Assuming you have never had your Beovision 7-32 Mark I updated to make it HD ready, then the latest TV software version is 6.33 with a part number of 8344431
    If you have previously had your Beovision 7-32 updated to make it HD ready, then the situation is a little more complex.
    Regards Keith....
  • 01-21-2010 5:44 PM In reply to
    Hi!
    With this update, will it be possible to play 2 channel PCM (iTunes via Coax)?
    Wy is it more complex with a updated BV7-32 MK1?
    /Ola
  • 01-21-2010 8:29 PM In reply to
    Dear Keith,
    Thank you so much for your kind reply. I never made any update to my BV7-32 so I will try to contact my local distributor and ask for this update. I will post my comments in the forum after the update.
    Mat
    PS: I am also curious to see if this update will fix the 2 channel PCM issue
  • 02-06-2010 9:16 AM In reply to
    Hi!
    How did it go?
    Did it solv the 2-channel PCM issue?
    /Ola
