Hi everyone. As i searched the forums, i did everything as i should but no picture.. :-(
Here is the setup.
Beovision 7-32Type 9321 (MK II).
PS3
The TV is connected to the PS3 with a DVI to HDMI cable.
The optical connection from the PS3 passes through a toshlink converter and connects into digital audio A4
I have the TV set as VAUX on AV4 with the A4 audio socket selected.
But here is the problem.
On AV4 of the BV's Connections Menu i can see the HDTV option with two selections i can make. Either NONE or YPbPr!!! I do not see DVI option there.
Does anyone know why?? Of course i have no picture from PS3. I also have to tell that my PUC has no PS3 on it.
But still the DVI option should be there…...
Any clues????
