Latest post 01-19-2010 3:44 PM by MartinM. 0 replies.
Page 1 of 1 (1 items)
  • 01-19-2010 3:44 PM
    • MartinM
    • Not Ranked
    • Joined on 08-07-2008
    • New Zealand
    • Posts 49
    Penta upgrades, tweaks and mods
    I’ve just completed an overhaul of my Penta MK2’s. Here’s what I’ve done to date:
    • Refoamed mid ranges
    • Cut off spade connectors and solder wires directly to speaker terminals
    • Replaced electrolytic capacitors on filter boards with Audyn MKT capacitors
    • Cut off spade terminals and solder wires to crossover boards.
    • Change wiring so that each crossover board connects directly to speaker terminals at the base.
    And for the Amplifier in the base:
    • Replaced capacitors in audio path with Wima caps
    • Replaced all other electrolytics with Nichicon 105 degree caps except the 10000uF caps which I replaced with Cornell Dubilier units.
    • Replaced (in my case) the TL072 opamp with OPA2134
    • Replaced trimmer resistors with Bourns cermet trimmers
    Adjusting the idle current was a bit fiddly as the replacement trimmers could only be adjusted from one side. So that meant having the transformer out lying on its side while I adjusted the trimmer and someone else measuring the voltage.
    So where to from here? Any other tweaks or mods to consider that others have done?
    The Pentas are connected to a BM7000 so perhaps that is the next project? Any suggestions on this?
    Filed under:
