Latest post 01-21-2010 7:46 AM by Dillen. 4 replies.
Page 1 of 1 (5 items)
  • 01-19-2010 7:25 AM
    Beomaster 6000 distortion.
    After a year or two of neglecting my 'vintage' B&O equipment (because it's been working!) I decided to have a look at some of my spare equipment. My Beomaster 6000 (the sloping-front model) has the expected problems with the motor-driven volume control (I will get round to re-threading the display when I can find my third hand...) but the biggest concern is serious distortion on the left channel. I am tempted to blame output transisters or capacitors in the output stages, but would welcome any advice on where to start from others who have encountered similar problems.
  • 01-19-2010 10:22 AM In reply to
    • chartz
    • Top 75 Contributor
    • Joined on 07-20-2009
    • Burgundy
    • Posts 984
    • Gold Member
    Re: Beomaster 6000 distortion.
    There's always the possibility of a main volume pot contact issue, mine suffered from that. I also had another strange "distortion" problem but it was a bad speaker connector! You never can tell!
    Jacques
  • 01-19-2010 5:22 PM In reply to
    Thanks. The fault doesn't change sides when I swap the 'speakers & appears on both sets of outputs. The volume control is a little scratchy in places, but there are many 'sweet spots'; while the distortion is always on the left & is present at all volumes that I have tried. I had hoped for an easy answer... but having checked the easy things I expect to have to do some disassembly. Any advice gratefully received!
  • 01-21-2010 7:43 AM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    These units are well known for capacitor problems, and member Martin Olsen (Dillen) has capacitor kits if you're good with a soldering iron. Send him a PM.
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 01-21-2010 7:46 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Well, as always - capacitors first.
    You really cannot judge anything with the old capacitors still in there.
    A kit exists for this.
    Then the idle current and DC offset trimmers, they are very often found bad. Not just misadjusted but actually defective.
