Hi Hank - we don't normally sell things like this on Beoworld - we give them away in the knowledge that these favours are returned at some point. Maybe not directly here but these favours tends to get repaid somewhere along the road of life. Before I fall into philosophy mode, check your "inbox" at the top right hand corner of the page where you will find a message from me.
They should fit your Beogram - if not then let me know as I may have some others laying around somewhere. When fitting them you need to first remove the brass sleeves before fitting the rubber bushes then reinsert them.
Chris.
