Hello BeoWorlders,
I have a problem once again, this time with a "new" Beogram 4002 and my 4000.
Both turntables has been unused for over a decade. The 4002 had the standard seized up lubrication and was fixed easily. When playing a record, there is sound in both channels, but I have to turn up my Beomaster 5500 to max to hear it.
My Beogram 4000 has stood still for a while. I replaced the burnt out sensor arm bulb and adjusted it a little bit. It came to life and tracks perfectly, but it has the same problem, but just the right channel. I have tried several styli and of course I use the phono stage of my Beomaster 5500, which is working fine with my Beogram 8002.
I suspect that the problem could be a stuck/corroded muting relay?
-Søren
Beocenter 9300, Beogam CD50, Beocord 5500, Beomaster 3400, Beomaster 4400, 2 Beogram 4000, Beomaster 8000, 2 beogram 8002, Beovox S-75, Beovox MS150.2, Beovox RL6000, Beovox S-35, Beomaster 6000, 2 Beocord 9000, Beocord 8004, Beocord 5000, Form 1, 2x Beolink 1000, Beo4, MX3500, LS4500. Born 1993.
