Dear All,
I have a Beovision 7-32 and I would like to connect a projector to my system. My tv is model 9312 and the part 1436400 ( Home Cinema control kit ) is already mounted in the TV. My projector might be a Sony VPL-HW10. The only HD source will be a TVIX-M6500A . So I have plenty of doubt :
1. Picture TVIX to BV7 and Projector
The output of TVIX is HDMI , the input of BV7 is DVI, the input of projector is HDMI. How can I manage to have everything working in the best quality ? Maybe a switch
2. Sound from TVIX to BV7 and projector
The outputs of TVIX are Coax/Optical/hdmi . I understand that the 5.1 sound will not be a problem as the BV7 recognize this format. But what about the stereo sound ? I heard that it is not possible ? Can I upgrade my TV ?
3. Control projector, curtain and TVIX with beo4 remote.
How can I control all the peripheral involved with my Beo 4 remote ?
Thank you very much if you can help me,
Mat
