Latest post 01-17-2010 2:03 PM by Spiros. 3 replies.
Page 1 of 1 (4 items)
  • 01-17-2010 1:32 PM
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    "Collecting Bang & Olufsen" by Jarman Brothers in pdf?
    Hi all,
    I do consider one of the best books ever read and frankly spoken going over it every day since it's the "B&O bible" when it comes to collecting our beloved brand.
    However and since I'm traveling very often due to business trips it's a bit much some times to carry it with me and would like to check any chances on buying a pdf version as well to have in on my laptop.
    Does anyone know if this already exists in pdf as well?
    Many thanks in advance.
    Best regards
    Spiros
    Best regards
    Spiros
  • 01-17-2010 1:58 PM In reply to
    Re: "Collecting Bang & Olufsen" by Jarman Brothers in pdf?
    No, it don't existx.
    My Bang & Olufsen....
    • BeoCenter 2 DAB/DVD mk.II
    • BeoVision 7-40 DVD mk.III
    • BeoLab Penta mk.III
    • BeoLab 4000 icepower
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beo 4 mk.I & mk.III
    • Beocom 6000
    • A8 Earphones
  • 01-17-2010 1:59 PM In reply to
    Not many authors risk putting out current works as pdf for obvious reasons. (I published something in pdf form with a password, only to find that some helpful colleague had managed to convert it to a Word document and had then altered it!)
    Much of the  'Collecting B&O' content is covered by the Beocentral website, and although it's not as easy to read as a book, with Beoworld, it gives you all you need (assuming you can get an online connection.) You could save webpages for later reading without an online connection.
    Graham
    I used to be indecisive, now I'm not so sure. [W C Fields]
  • 01-17-2010 2:03 PM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Hello Graham,
    Many thanks for the tip. It is really unfortunate and indeed it is quite risky I assume.
    I will give it a try through Beocentral and at least I will carry a piece of my beloved book!!
    Best regards
    Spiros
    Best regards
    Spiros
