Latest post 01-17-2010 7:38 AM by Mark. 6 replies.
Page 1 of 1 (7 items)
  • 01-17-2010 5:58 AM
    • Mark
    • Not Ranked
    • Joined on 01-16-2010
    • Suffolk, England
    • Posts 6
    Beosound 3200 - help!
    Hi, I confess that I just joined as a bronze member as I have problem with my beosound 3200. I cannot switch it on (tried everything).  BUT I can play a CD through it using my beolab 3500 which is linked! However, this times out after a couple of minutes & the whole system shuts down.
    There is a red & a green light on but no life otherwise. I cannot access any functions on the keyboard.
     Resolution tips gratefully received. Thanks, Mark.
    The system is a Beosound 3200 + Beolab 6000 speakers + a Beolab 3500 in another room.
  • 01-17-2010 6:12 AM In reply to
    Re: Beosound 3200 - help!
    You have to set the correct Audio option for your BS 3200.
    Put all devices to standby.
    Go to the room with the BS 3200.
    Hit the (red) standby button & <LIST> at the same time.
    Press <LIST> until it says OPTION? Pres <GO>
    Press <LIST> until it says A.OPT, then press <2>
    /Frank
  • 01-17-2010 6:28 AM In reply to
    • Mark
    • Not Ranked
    • Suffolk, England
    • Posts 6
    Hi Frank, thanks for your reply. I just tried your suggestion (3 times) but no change. The red light flickered when I hit the <2> but nothing more.  Any more ideas?
    Mark.
  • 01-17-2010 6:54 AM In reply to
    it looks like a pin-code error.
    do you put a pin-code in the BS3200?
    if yes: unplug the system for 0.5 h. re-plug it. enter the pin-code.
  • 01-17-2010 7:05 AM In reply to
    • Mark
    • Not Ranked
    • Suffolk, England
    • Posts 6
    Hi tried that, left it unplugged overnight, when I plugged back in this morning it did not ask for a pin code. (I do use the pin code protection). I am trying again for 0.5hr. I will let you know what happens.
  • 01-17-2010 7:13 AM In reply to
    hi Mark,
    this isn't correct. If you installed a pin-code, it should ask for the pincode after the bs3200 was unplugged from the mains for about 0.5 h.
    So if you unplugged it overnight it should ask for a pin-code!
    you should also try it with everything unplugged (PL/ML/etc)
  • 01-17-2010 7:38 AM In reply to
    • Mark
    • Not Ranked
    • Suffolk, England
    • Posts 6
    Hi, Done that, no change. No request for pin code. I fear there maybe something more serious than a system error! Any further suggestions gratefully received.
