1st March February 2012
Latest post 01-20-2010 11:14 PM by elephant. 45 replies.
DrDimitris
- Joined on 04-25-2007
- Posts 560
Re: Mac to B&O system, how?
frog:
Put your videos in the Photo folder and select the movie as if you are looking at a photo and it will play. Note that FF/REW pause all work too.
Thank you. Sorry if i ask to much but if we take the procedure from the beggining is like that:
Download VLC Player
Run in on Beomedia being already in the Beomedia desktop as usual.
And that's all?? Correct me if i am wrong on this please
scanorama99
- Joined on 01-19-2010
- Posts 93
I am looking towards trying to make some kind of interactivity between my mac and beo stuffs.
Today I have
office: beovision 6 as computerscreen connected to mac mini (beoport not installed currently but I have it)
livingroom: avant realflat + speakers
kitchen: own a spare 22" beovision 6 that I wonder if I can sparkle it into life :)
I know I can wire my system together to get sound and beo´s own remote control signals all around the apartment. But if I want to add, say interactivity showing streaming video from the net to my kitchen from the mac mini what is the most convenient solution?
beomedia is out of the question since it mostly shows stored material and I am talking about the functionality in example as Plex has got.
I also dont see how this box distribute video to other sources? By draging an extra scart cable like 15 meters ? probably not ?
Anyway I would like to keep the hardware I have and instead use software as much as possible to max my interactivity in my home, how should I think ?
Am I correct that I should place the ir-reciever from beoport always in reach from the kitchen since probably the kitchen tv will not recognise for example if I try to switch songs in itunes and run a videocable of some sort + a masterlink cable?
Currently I run rca soundcables from my mac to my beovision (andr activate screen with PC command on beo4, and I guess I need to change that to masterlink instead of rca when I install the beoport in this multiroom setup right?
whatabout the same situation in livingroom, masterlink + videocable and all done ?
I guess this will be a mess since I need to fiddle some with the Option alternatives since i´m combining computer stuff with also sometimes want to use regular tv
scanorama99
- Posts 93
Another dumb question: I have found lots of boxes to convert the frequency of the beo4 signals to other devices via example lintronic or ir-trans but is if there was a software based solution that made my macbook for example understand beo4 codes without extra external boxes I would be really glad. That would be integration at its best but probably the beo remote signals are completely ignored by apple´s regular reciever ?
Using the beo4 as mouse on the screen would be really cool, I dont like having many remote controls / mices / keyboards but instead keep it as simple as minimalistic as possible
Daniel
- Joined on 04-17-2007
- Svinarp, Sweden
- Posts 1,284
Hi!
As a Mac rookie I can't help you, but I advice you to start a new thread in the Mac forum here on BeoWorld. I think more people with knowledge about Mac+B&O will see your questions.
I didn't know about the Mac Forum (or rather had forgotten it) when I started this thread here. Also this thread should have been posted in the Mac Forum.
elephant
- Joined on 04-16-2007
- Melbourne, Australia
- Posts 2,215
I think you should look at Phillipe's beta LinkPlayer that has extended functionality beyond the Net-Music and Net-Radio of Anders' BM-Link so that we now have something that exceeds a BeoMedia (I believe).
I have been testing LinkPlayer since November and now use it daily.
I have been using LinkPlayer to launch and control PLEX for more than a month now and I am very happy with driving PLEX via my Beo4.
Similarly I have been experimenting with linkPlayer's support of my Elgato eyeTV hybrid. And I am very happy with my tests of this week's release of LinkPlayer which provides direct access to the catalogue of EyeTV recordings I have made (live TV capture, plus capture of home movie videos transferred from my B&O VHS).
I have tested the lasted LinkPlayer's access of Boxee for completeness of testing, but I am no fan of Boxee and do not intend to keep using it.
My latest hardware extension has been to get a generic brand CRT TV to be a link TV for my BV8.
This is my set-up is as follows, hopefully this will give you an idea of what cabling options can exist:
Room 1 -----------------------------------------------------
- BeoSound 4 with BeoLab 6000s; system is master linked to the BeoVision 8-32
- generic brand CRT TV connected to a B&O RF Amplifier (non-return version) via RF coax
Room 2 -----------------------------------------------------
- B&O Master Link distribution box (has 6 ML ports for patching ML cables to form a star ML network)
- BeoVision 8-32 with DVB-T system module that gives me Master Link support
- BeoPort with IR eye, master linked via distribution box with BeoSound 4, BeoVision 8, and a Beolink Wireless 1 (transmitter)
- MacBook connected via audio cables to the BeoPort and to the BeoVision, USB cable to the BeoPort, and DVI/HDMI cable to the BeoVision
- Elgato EyeTV Hybrid is attached to the B&O RF Amp via a coax and also to the Foxtel STB via composite cable
- BeoLab 3s, currently connected to BeoVision 8
Room 3 -----------------------------------------------------
- BeoLink Wireless 1 (receiver) with IR eye
- BeoLab 4s
Room 4 -----------------------------------------------------
- BeoLab 4s
- another generic brand CRT TV that I can't get to tune to the Link frequency coming from the BeoVision 8 via the B&O RF Amplifier
I hope that helps you appreciate some of the possibilities that you can achieve with some extra hardware, cabling, and software such as LinkPlayer.
Ed~2
First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
cooldude
- Joined on 03-14-2008
- Posts 971
Just downloaded the latest update of linkplayer, it is mighty impressive with the added functionality.
Not having used a beoport in ages, it took me some time to find one and configure andset it all up. For testing I did install it in our main, simpler setup : macmini with beoport with Ir eye as audio master and the AV7000 as video master connected to Kuro plasma, linked with beolink converter to Ouverture. I use a separate, full beosystem 7000 to pipe music around the rest of the house for now. Apple tv's take care of distributing video wireless.
Using itunes works perfectly, so far I cannot report any major problems. I do not get any display functionality on my Ouverture, but that should be normal as it does not have nmusic capabilities I think. I am sure somebody will correct me if I'm wrong ...
I love the full-screen mode with the red dot matrix font and that it displays the tag and cover image. However it seems that my mac is full resolution mode and displays the fonts and cd covers very small (ok...I admit it's 50" screen..). I guess that the only way is to change the mac mini's display settings ?
I have tried Plex with it briefly and seems to work well. I am currently upgrading my NAS which will be dedicated to video and itunes will again have it's own dedicated drive, directly connected to the mac mini. I have slowly been ripping my oldest dvd's to the NAS. I still have a collection of 50 regular and 60 or so blu rays that will solely be handled by the Blu-ray player. Also I am now busy upgrading plex to run with newly installed snow leopard upgrade on the mac mini. Also changing plex with a new skin that looks great. Sorry for the bad cell phone pictures.
DrDimitris
- Posts 560
cooldude:
Hey cooldude, How do you assign Beoport as Audio Master???? Is that an option you give with Beo4???
elephant
- Posts 2,215
hey that's real cool
I like how you have B&O-ed the PLEX Skin.
I had played around with skins under XBMC (from which PLEX was spawned) but found them a little flakey and so reverted to PLEX.
Where did you find the instructions to do the PLEX skin, and would you like to make your PLEX skin available to the rest of us?
Ed~2
cooldude
- Posts 971
elephant:
Ed~2
thanks for the interest.
As I am building my up system, I thought a more B&O styled interface would be a little more appropriate. I first thought of writing one myself (maybe influenced playing with the Beosound5), which is not all that hard to do if you have some basic programming skills, but time not being on my side I opted for the easy way out and installed the Plex Skin Installer script.
The script will install several skins at the same time. IMO PlexAeon and PlexAlaska being the most polished looking and cusomizable ones. They all will be available through the Plex setup menu. You can always delete the ones you don't like.
You'll find all the info and how to on following link http://forums.plexapp.com/index.php?/topic/10107-plex-skin-installer-script/ Please note you'll have to run GIT first and run the script in the OSX terminal.
I did change the Icon pictures to B&O ones. You'll find them in (Yourmacname)/Library/Application Support/Plex/Skin/PlexAlaska/media/backdrops.
That folders holds the folders (movies, tvshows, music,....) that hold the pictures for the menu icons. Just put whatever you want. I couldn't be bothered googling stuff, so I went to the B&O website and downloaded the images from the media section....plenty stuff there.
If you have any questions PM me, and I'll do my best to answer you asap.
cooldude
- Posts 971
DrDimitris:
cooldude:
Yes, but works only if you have IR receiver eye connected.
cooldude
- Posts 971
elephant:
Ed~2
Regarding stability : It's about as stable as the standard one so far, however it seems that both snow leopard and its apple remote problem play a role in this. (a time-out somewhere?) and funnily, in my systems it seems to work ever so slightly smoother in combo with the beoport.
PhilLondon
- London
- Posts 2,545
cooldude:Yes, but works only if you have IR receiver eye connected.
I did not follow the conversation but just would like to say that Beoport can be used as an audio master, without an IR receiver, using LinkPlayer. If there are any issues while using it this way, please let me know.
cooldude
- Posts 971
PhilLondon: cooldude:Yes, but works only if you have IR receiver eye connected.
Hi PhilLondon,
I remember that I could not get it to work a couple of years ago, but that could either related to the old BMlink or old beoport software.
Will try later and see how it works.
scanorama99
- Posts 93
Sounds very nice to have it as audio master, that I recall was not possible when I got it back in the early days (like 8 years ago)
What options-settings is correct to have here if You read my setup some posts ago if I want to use the beoport as master and what is the difference if Its not master ? forgive me, it was some years ago I played around with these settings...
And again, do anyone know if it is possible / practical to have the beo4 as mouse pointer? I imagine I could use in on lets say a projector/beamer when in my livingroom and really control everything I want with lets say the arrow buttons in the middle ?
Pestria
- Joined on 04-18-2007
- Posts 51
Elephant
Thanks very much for this - some really good ideas there.
Am I right in the following?.....
1. By looping the RF out from the BV8 back into the Mac via Elgato TV you can record whichever video signal is fed into the BV8?
2. By connecting the Mac via HDMI you can 'see it' in link room TVs via the RF out from the BV8?
3. Audio from the Mac is distributed via the Beoport and Master Link?
4. The Mac is fronted by Plex and Plex recognises Beo4 commands via the STBC?
If so then it's a genius set up - one which I'd certainly like to replicate.
Kind regards
AP
PhilLondon
- London
- Posts 2,545
scanorama99:Sounds very nice to have it as audio master, that I recall was not possible when
BM-Link only works in option 4,5 or 6, which means you must own an audiomaster for it to work.
Beoport can work in option 2, using BepPlayer (the PC version of the software made by B&O) or LinkPlayer.
This allow you to listen to N.MUSIC and N.RADIO through the TV speakers, or in any link room. The Mac CD can also be used.
scanorama99:And again, do anyone know if it is possible / practical to have the beo4 as
LinkPlayer allows you to use the Beo 4 as a mouse. I would not call it practical ;-) but it is possible. More info here: http://web.me.com/philrobin/LinkPlayer/Mac_Control.html
elephant
- Posts 2,215
Pestria:1. By looping the RF out from the BV8 back into the Mac via Elgato TV you can record whichever video signal is fed into the BV8?
Correct, I use the "Active Antenna" that comes with the DVB-T system module: you get a fourth AV with SCART, the DVB-T input aerial, the RF output, and a Master Link port.
Caveat: any analogue signal, so something coming via HDMI (& therefore in digital form) can not be.
Surprise: I thought the caveat would mean my DVB-T would not be transferred but I have found it is!
However for better quality I also connected my Foxtel via a SCART to composite (red, white, yellow cable) to the composite video input of the Elgato EyeTV Hybrid.
I am also able to distribute content from my DVD player since it is attached via a SCART.
Pestria:2. By connecting the Mac via HDMI you can 'see it' in link room TVs via the RF out from the BV8?
Sadly no.
Because of the caveat above the MacBook's output is not transferred, same limitation exists for the current MacMini.
There maybe second hand, older versions, of the MacBook or the MacMini that have analogue outputs (e.g. VGA on an older MacBook that may work).
On the other hand the Apple TV supports component output, and so you could use that especially as ATV Flash (mentioned elsewhere in these forums) unlocks the Apple TV for supporting a wider variety of video formats.
Pestria:3. Audio from the Mac is distributed via the Beoport and Master Link?
Correct.
I split the audio output form the MacBook to both the BeoPort and the BeoVision.
The BeoPort path is used for Net-radio and Net-Music (even to the BeoVision) and to the "link" rooms which includes the BeoSound 4 room.
Even if the BeoSound 4 room is not active, the BeoSound still displays (silently) the details of the Net-Radio broadcast and Net-Music tracks.
This functionality is supported by either of BM-Link from Anders, or LinkPlayer (still in beta) by Phillipe.
The BeoVision path is used when I run the system in Beo4 "PC" mode so that I have the Mac video (via HDMI) and Mac audio (via headphone jack cable splitter).
LinkPlayer as a media centre enables me to use my Beo4 to control the MacBook and the BeoVision to run iTunes, iTunes CD, FrontRow iTunes, FrontRow DVD, EyeTV aerial (analogue, DVB-T, Foxtel), EyeTV recordings, iPhoto slideshows (accompanied by iTunes music), PLEX (iTunes audio tracks and videos (TV Shows and Podcasts), DVDs captured via Handbrake or MakeMKV), and Boxee (I don't use it since I do not like its interface).
I have even used LinkPlayer to browse (but not post to) BeoWorld.
I can also use the BeoVision simply as a computer monitor with audio, but in that mode I do not use LinkPlayer, and so I have a wireless keyboard and wireless mouse (just upgraded that to the magic mouse).
Pestria:4. The Mac is fronted by Plex and Plex recognises Beo4 commands via the STBC?
Not quite, I do have my second IR blaster available for using on the MacBook which I have tested.
But (for the moment) I prefer the configuration where the Beo4 interacts with the BeoVision and with the BeoPort's IR eye.
The operation is quite seamless and even though the Beo4 commands are intercepted by both units Phillipe has managed to create an environment where the LINK- prefix is not needed.
The only glitch I have experienced is when I go "SPEAKER" + "2" which correctly causes the BeoVision to switch to using the outboard speakers, but also causes LinkPlayer to swap to the playlist that is number two in my iTunes setup.
Pestria:If so then it's a genius set up - one which I'd certainly like to replicate.
It is a "genius" set-up because of Phillipe's perseverance and skills in making LinkPlayer far more than what BM-Link (or Beoplayer, or Beomdeia 1) ever were.
However a lot of praise is also due to the genius of the BV8-32 even though it does not have a Beosystem 3 platform inside.
I have been astounded by the BV8's flexibility and how far I have been able to push its capabilities.
Note however that I do not have any ability to do surround sound processing with this set-up.
Hope that helps clarify options available to you -- Ed~2
PhilLondon
- London
- Posts 2,545
elephant:Correct, I use the "Active Antenna" that comes with the DVB-T system module: you get a fourth AV with SCART, the DVB-T input aerial, the RF output, and a Master Link port.
The caveat is the following: B&O TVs can only distribute standard definition sources, but cannot distribute HD sources. You can however connect some sources like HD set top boxes to the HDMI and to the SCART at the same time, so you can distribute them. elephant:The only glitch I have experienced is when I go "SPEAKER" + "2" which correctly causes the BeoVision to switch to using the outboard speakers, but also causes LinkPlayer to swap to the playlist that is number two in my iTunes setup.
This should have been fixed in 0.8. There are probably some similar issues that I haven't fixed with the Picture, Format or Stand keys.
elephant
- Posts 2,215
PhilLondon:This should have been fixed in 0.8.
Thanks Phillipe - I will check.
PhilLondon:HD sources
I forgot to mention that one advantage that I got from using the Elgato EyeTV to tune into my Digital Aerial and pick up HD signals which are then downscaled for display to my MacBook and then output onto my BV8-32.
So now I am able to enjoy the content (but not quality) of some 5 Freeview HD channels.
scanorama99
- Posts 93
Ok I connected my beoport (maybe Its not beoport, it says beolink pc-2 on the manual?) with an ir-eye
Anyway, I got connection and I can make things happen and control it with my beo4 remote both in bm-link and linkplayer.
The bm-link is flowing ok and I can start both itunes, radio and frontrow.
However the linkplayer crashes around 9 times out of 10. I have played with various settings for hours now. Very strange. I cannot mail any feedback since I dont use mac embedded mail-client. But for example, if I set the button dtv on beo4 to start web or front row or whatever, I might be able to start it once, but if I then quit the linkplayer and start it again and press dtv either on the virtual remote or real beo4 the program crashes, next time crashes... over and over... exactly when I press the source button. I have tried every source and none work fully. Tried all options-codes 0-6 also.
Too bad since I like the program very much the few times it worked.
I have snow leopard and running a intel mac mini 2,ghz 4gb ram
Any ideas?
