auric:
Jeff: in my 8000 mostly
TL 072CP
uAF 772TC
1 NE5532 in the phono stage.
NE5532 would also be a good op-amp for "warmer" sound. These are used extensively in Studer tape recorders.
You have to be careful about replacing opamps with a completely different internal design, though. This goes especially between the likes of TL072 (which is a BiFET opamp) and NE5532 (which is bipolar). Both are very good audio opamps when used properly, but may fail badly if you try to simply interchange them.
This is mainly because of the vastly different characteristics of the input stages; the FET inputs have practically zero input bias current (in the order of few tens of picoamperes), while the bipolars don't - especially the NE5532 has an input bias current of almost 0.5 mA. Thus dropping a 5532 into a very high impedance source might even disturb the operation point, but most importantly its bigger input noise current will create a lot of noise in a high impedance circuit. The noise characteristics of NE5532 make it mostly suitable only for circuits that have a source impedance of 10 kohms or less.
The BiFET opamps also have much better DC offset specs; if you drop bipolars in their place, you might even need to introduce some new decoupling caps in the signal path (B&O designs usually have them all over the place already, though
Some of these imperfections might actually even sound good, but it is then pure luck instead of the result of using a "better" opamp.
TI itself has recommended TLE2072 family to be used in place of TL07x if higher specs are needed. Less noise, but the slew rate is even bigger, and I guess those would then sound even more sterile.
