1st March February 2012
Latest post 01-14-2010 12:14 PM by joeyboygolf. 13 replies.
01-13-2010 11:29 AM
DCI
- Joined on 12-08-2009
- Boston
- Posts 18
Beogram 4500... playback issue.
I recently aquired a Beogram 4500 and NOS MMC2 stylus and it has been sounding superb! But recently it has been cutting out, the player continues to operate in every function, but the sound stops. Its like it has a short circuit, the sound comes and goes. I hear a static like pop and the sound stops,. Leave it alone, move it, or turn it off for awhile and it starts playing like nothing happended and then a bump or close of a door and the sound stops agian.
Anyone who has any insight, or where to look first?
Thanks!
Dave
burantek
- Joined on 05-04-2007
- SE USA
- Posts 6,214
Re: Beogram 4500... playback issue.
Welcome to BeoWorld!
Tracking weight?
DCI
- Boston
- Posts 18
I can hear the needle picking up the sound, but all I can hear when I turn my system up to 50-60 is static, then it will make a static pop and its playing again ( this rarely happens now). Could it be the built in preamp...or the muting switch? Anyone have any ideas?
Thanks...
burantek
- SE USA
- Posts 6,214
I am sorry...
I should have asked...
What is the BG connected to?
Your 4500 does have a RIAA built in, but the muting would be a function of what it is connected to... short of the deck's relay.
DCI
- Boston
- Posts 18
Its connected to a Beosound 9000. The 4500 has a RIAA built in. I just put on an album......nothing but static with the Beosound turned up fairly loud.... let it play for the whole album then a loud static "pop" and its fine, music playing.
The album ends, put on a new album and again.... static. The problem has happend several times over the last week but it has gotten far worse and and now rarley "pops" on.
burantek
- SE USA
- Posts 6,214
DCI:
Had the exact same setup!
As this is new to you... Might you have a spare cartridge to try? Sadly, NOS cartridges may be worse than one that has been lovingly used...
Where are you located?
burantek
- SE USA
- Posts 6,214
DCI:
Im in Boston. No other cartridge to try! Tons of great new Lps....and no love from my Beogram
Well, I am going to go out on a limb and suggest it could be the cartridge. At the least, it would be the first thing I would test.
I am running short on cartridges, but I will happily send one off to you for testing, unless a member in your vicinity might have one closer.
In the meantime, take a look here: Soundsmith ...next door to you in NY.
joeyboygolf
- Joined on 04-16-2007
- Ely, Cambridgeshire, UK
- Posts 3,252
Could also be the mute switch in the deck!!!
Worth checking that first, before splashing out on a new cartridge.
burantek
- SE USA
- Posts 6,214
joeyboygolf:
Mute in the deck: Perhaps it can be exercised?
Agreed... consider my LINK to Soundsmith as research only... Don't spend any $ until your cartridge might be tested faulty.
Is the DIN line in good shape? Maybe something loose there?
Is the stylus guard completely out of the way -not contacting the record?
It seems like subtle bumps (door closing) can cause this...
DCI
- Boston
- Posts 18
Thanks for the replys, and the cart offer! I have ruled out the mute switch in the deck, it is working properly. Looks like I will be buying a couple of cartridges to play with....and maybe sending the old one to be rebuilt, does anyone know the Axel site, do they speak English if I email them?
Headed to Italy today, back in a week and will test with the new carts then.
burantek
- SE USA
- Posts 6,214
Dave,
I have not used Axel, but plenty have here. I have read nothing but good things about him/his work.
Your call with repairing/replacing your cartridge, but I would hate to see you waste the $, if it is not the cartridge.
joeyboygolf
- Posts 3,252
DCI:
Axel will understand your email in English.
Page 1 of 1 (14 items)
