LDR stands for Light Dependent Resistor. It's resistance varies according to the light that shines on it.
Inside the Beomaster 1900/2400, a tiny closed casing contains a lamp surrounded by four LDR's.
The volume control circuit changes the light output from the lamp which in turn changes the resistance
of the LDR's.
Two of the LDR's are sitting directly in the signal path handling the volume, the other two handles loudness/filters.
The circuit has been made so that the more light, the lower volume.
This again means that if the lamp burns, the volume would be brought to max.
- If it hadn't been for a little clever circuit that constantly monitors the lamp current and if it falls
below a specific level, the circuit issues a mute command.
If the lamp burns the Beomaster will be silent (or nearly silent).
Different LDR's:
The two red volume indicator lamps on the front panel does not control anything, they just indicate.
Remember that electronically controlled volume controls (without a motor, gearbox and a potentiometer)
was breaking news and also one of the things that made the Beomaster 1900/2400 so technically advanced
for their time and also helped to path the way for a remote control.
