Latest post 06-17-2007 1:52 PM by joeyboygolf. 5 replies.
Page 1 of 1 (6 items)
  • 06-16-2007 10:13 PM
    What is the maximum length
    that we can run Powerlink cables?  Do we just use the female-female connector to connect 2 Powerlink cords?
    THanks, K
  • 06-17-2007 2:09 AM In reply to
    Re: What is the maximum length
    I'm sure that I've read 60 metres somewhere but I can't find the reference now.
    Just found it on www.beotech.co.uk and it's 100 meters
    Regards Graham
  • 06-17-2007 11:37 AM In reply to
    Thanks Graham....
     Do i need the 7 or 8 pin powerlink cords for my 8000's and Penta 1's?????
    Thanks again...much appreciated.
  • 06-17-2007 12:17 PM In reply to
    • Russ
    • Top 100 Contributor
    • Joined on 05-07-2007
    • Washington, DC USA
    • Posts 641
    PoweLink is always 8-pin...the correct question is "how many conductors?'  ;-)  The 8000's can use ANY PL cable you want to run.  I don't think Penta 1's have a PL socket at all; in the case of Penta 2 & 3 you want to run the 8-conductor cable in order to get the data display to work.  What stero system are you using?
    Russ
    We kid because we love.
    Bang & Olufsen Tysons Galleria
    McLean, VA USA
  • 06-17-2007 1:15 PM In reply to
    Thanks Russ...
     I'm using the AV/7000 to drive the speakers linked to a BS9000.
    So Powerlinks off the AV7000...... I got the adapters at the speakers to change the powerlink over to the penta 1's...
     If i use the 8 conductor wires...can i get the displays to work on the penta 1's off the AV7000??? With the adapters of course...
     Thanks..
  • 06-17-2007 1:52 PM In reply to
    I don't think the displays will work with the adaptors.
    Regards Graham
