I've just bought a Beo5. I have the B&O config tool (my dealer gave it to me) running just fine. I configured my B&O Equipment and I downloaded the XML-File for AppleTV here in the downloads section and now it works 100% controlling my AppleTV with Beo5. Great!
Now I would like to add some other ThirdParty devices. I've read here, that it is possible to capture IR-Codes with the PocketPC Software "RemoteControl II". Since I still have an old HP iPaq I tried this and captured IR-Codes for my Technisat PR-K, my Philips HDR and a small Samsung LCD. It worked great and I got all the codes I wanted.
And here I got stuck now.
I've got code like this (the example is the "Power" command from my Technisat PR-K):
0000 006c 0022 0002 0157 00ac 0016 0015 0016 0015 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0040 0016 0015 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0015 0016 0015 0016 0015 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0040 0016 0040 0016 0015 0016 0040 0016 0040 0016 0040 0016 0040 0016 05fb 0157 0056 0016 0e66
Using the CodeLearn Section of the Lintronic Software as described, the convert button remains greyed out. Do I need to buy the Lintronic TT455-RT-238 box and have a connection or is there another way to convert this code?
I was reading a lot here in this forum, but I only found out, that it is possible to use "RemoteControl II" for capturing and then convert the codes, but I didn't find a description how to do it. It would be great if someone could give me a hint how to do that.
Thanks in advance
Jasper
