1st March February 2012
Latest post 12-11-2010 6:25 PM by Razlaw. 20 replies.
01-11-2010 8:12 AM
Keith Saunders
- Joined on 04-16-2007
- Technical Advisor, Little Ann, Hampshire, UK
- Posts 3,810
PUC (Peripheral Unit Controller) List Updated
I want to draw members attention to the fact that the PUC Library List has been updated HERE
This library is available to B&O dealers to select from and assemble into a file for uploading into their customers PUC.
Razlaw
- Joined on 04-24-2007
- Illinois
- Posts 1,770
Re: PUC (Peripheral Unit Controller) List Updated
Thanks for the great info! It lists a GDishDVR with two versions, 1.00a and 1.10a. Also lists Sony BDP-S300 with two versions, again 1.00a and 1.10a. Any idea what the differences are between the versions and also is there any way to tell which version we have on our BV7?
Beosound 1, 5, 2000, and 3000
Beotime, Beotalk, Beocoms
Keith Saunders
- Posts 3,810
The changes are small as follows and you should use the latest version:-
GDishDVR
The changes relate to the timeout period when using PLAY (GO) and adding 0 (GO) macro command.
Sony BDP-S300
The changes relate to adding 9 (GO) macro command plus adding timeouts which were previously zero.
Razlaw
- Illinois
- Posts 1,770
Nobsi
- Joined on 01-11-2010
- Posts 6
@ Keith,
do you have any idea, if and when the HUMAX icord HD+(plus) ( I know, the HUMAX icord HD is already included ) is going to be integrated?
regards
Nobsi
Nobsi
- Posts 6
Thanks for your quick response. Unfortunately, the Humax icord HD is not the same as the Humax icord HD+. In the list I only find 4 versions for the Humax icord HD ( Versions 01.00a to Version 01.30a ). the Humax icord HD version 01.30a does not work with a Humax icord HD+.
regards
Nobsi
Keith Saunders
- Posts 3,810
Nobsi,
Sorry about that, I missed the importance of the + sign, well I made some enquires and apparently there is going to be a Humax icord HD+ PUC update in the very near future, possible later this month..
Nobsi
- Posts 6
Thank you for your quick reply.
regards
Nobsi
david707
- Joined on 04-20-2007
- Posts 295
I notice the Ipod dock is in there but no mention of the Microsoft Zune. Perhaps the XBox has the same codes?
David
beolion
- Joined on 10-20-2009
- Posts 245
I am considering a POPCORN HOUR C-200 or a TVIX M6600, but the PUC list for the Popcorn only says:
POPCORN STB POPCORNHOUR V01.00a
How can I know if the PUC code can control the C-200?
There is something about B&O.....
Razlaw
- Illinois
- Posts 1,770
Is this list still the most current?
Hiort
- Joined on 04-17-2007
- Posts 383
Hi Keith,
Does the dealers have access to the PUC list online, or are they relying on Struer releasing updates of the PUC list?
/Claes
_____________
Happy owner of: BV10, 2 x Beocom 2, Beocom 6000, Beocenter 2, Beolab 3, Beolab 2000, Beo4, Beolab 11
1:st prize winner Beoworld January Price Draw.
Razlaw
- Illinois
- Posts 1,770
Keith Saunders:
No, the list is NOT up to date. There is at least 40 units I need to add to the list which I will try and do in the coming weeks.
Thanks. We have just ordered a new tv and want to make sure I have the latest and best puc versions.
nguyenvanbo
- Joined on 04-13-2010
- Posts 7
Keith
Are you able to locate the PUC for Sony RDR-HXD970. Alas neither versions 1070 or 995 work.
Many thanks
Nguyen
Razlaw
- Illinois
- Posts 1,770
Will the list referenced in this thread be updated at any time?
Keith Saunders
- Posts 3,810
Razlaw:
The simple answer is YES.
I am planning to produce a full update over the Christmas period.
beolion
- Posts 245
Hi Keith
Sounds just great, actually, it could be great if B&O themselve would produce this list. They must have a much more detailed list internally which from my point could be interesting in looking at. Also to see what is planned to go into the PUC list.
Btw, the new Tvix M6600 PUC works perfect with my Tvix 6600, there were some stuff that did not work on the 6600 with the 6500 PUC.
Razlaw
- Illinois
- Posts 1,770
Keith Saunders:
Razlaw:
Thanks!
Razlaw
- Illinois
- Posts 1,770
Keith Saunders:
Razlaw:
Thanks!
Page 1 of 1 (21 items)
