Latest post 01-11-2010 5:42 AM by tournedos. 4 replies.
Page 1 of 1 (5 items)
  • 01-10-2010 6:59 PM
    Where in the states can I buy powerlink sockets....
    Are they some standard type of socket?    I'm not looking for cables, but something I can mount on a wall plate.
    Thanks,
    Corey
  • 01-10-2010 8:00 PM In reply to
    Re: Where in the states can I buy powerlink sockets....
    I am not sure if it is what you are looking for, but Panamax makes wall sockets that have connections for Powerlink, Masterlink, and electricity. We purchased our from a B and O dealer and had them installed by the dealer.
    http://www.panamax.com/PDF/Datasheets/MIW_BO_Fact_Sht-5.pdf
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 01-10-2010 9:07 PM In reply to
    • Alex
    • Top 500 Contributor
    • Joined on 04-16-2007
    • New York, NY
    • Posts 176
    Lutron makes some.  If I remember correctly they're about $90 each, they fit in a standard metal/plastic socket backbox and they are available in the popular decora style and colors.
    FYI though you will only be able to order these through a B&O dealer.
    Store Manager Bang & Olufsen Broadway 927 Broadway New York, NY 10010
  • 01-11-2010 5:25 AM In reply to
    I actually want to make my own wall plates.
    I found 8 pin DIN sockets online,  is the powerlink just a standard 8 pin din?  Or a special socket where the pins don't line up with a standard DIN?
  • 01-11-2010 5:42 AM In reply to
    Yes it is a standard 270° 8-pin DIN like this.
    There are also another types of 8-pin DINs where the 7 outer pins form a different angle than 270°, but they will be harder to find.
    -mika
