Hello,
I have the new BV 10-40 with the DVD-HD-Module and I am very disappointed because timer-recordings from the module are not possible with my DVD2.
Therefore I ask you:
1. Are timer-recordings from the DVB-HD-module only possible with the HDR2?
2. Does it make sense to buy a HDR2 because of only integrated analogue tuner and no HDMI port?
3. Which combination of Beovision and Recorder do you use together with timer-recordings from the module?
Thank you very much for your feedback!
Regards
