My apologises if this subject has already been covered, but there are a few problems after I had a replacement Sky HD box for my BV7-40 Mk II. The new box is a Pace, while the (faulty) box was a Thompson. The installer insisted that the SCART cable be turned off, although the previous Sky box had the SCART connected. Can anyone please advise which is correct? The tv has the usual HDMI/DVI upgrade and connection.
After fitting the new Sky box, I find that the Beo4 no longer controls the 'box. I have checked with my local B&O dealer (they are very helpful) and all the usual menus on the tv are set correctly for 'box operation, and the front connection is in the correct place. Is there something else which I could check?
Furthermore, when turning off the tv on the previous 'box, using the Beo4, it reverted to stand-by. This feature is missing from the present setup. Again, is there anything which I should do so that the Beo4 could return the 'box to standby?
Finally, the tv has not had any SW upgrades for at least two years. I do not know how to establish what upgrades, if any, the tv may have had or indeed may need, so if anyone does know if there have been any upgades in the past two years, I would very much appreciate details of what they are, so that I can get the local dealer to install any which may be needed.
Again, my apologises if these points have already been covered, and my thaks for any advice which you have to offer.
Villarsch
