Your Creek Destiny apparently has different levels of amplification. The manual says that the preamplifier part of the Destiny should only be in active mode if the source level isn't high enough. You can even adjust the level of amplification, in active mode, at the bottom of your amplifier, but first you need to find out whether passive mode is adequate.
